Cool simple "clean" CFA
Here comes the Starship 😀
Everything is in place except 4 big ones. First test will go "as is" to make sure IPS is fine (no errors, etc.)...
Here goes v02.
I have also added the "BIAS" plug for overcurrent sensor - in the middle of PCB. Size is the same, just "cleaned up" some space 🙂
Have fun! :spin:
Not just that, Q24, Q25 driven CCS for input buffer in VAS bias feedback, could also eliminate output DC offset since they influence opposite drive side, very nice idea. :up:
Maybe C35, C36 are little too low on value, also R5, R8 should be much lower (2,5 k) providing 1 mA input buffer bias, waiting for measurements. 😉
Thank you LC 😉
This is what I mentioned as an "elegant implementation" of the CCSs in post #51 🙂
Just tested with no output transistors and no load.
Runs well. The funny thing - you were right, probably it will run fine with no servo, I'llll try it later - there's no power-on blip at the output at all. Not a short one or low-level one - just nothing 😱
Moving forward...
Measurements!
OK, finally - testing and measurements.
I tested it with MJL21193G/21194G at the output.
Only front-end to-92 transistors are roughly matched (within more or less 20%), all the rest - no matching.
First of all - it's very stable. No sign of any kind of oscillation whatsoever.
I have checked the offset with no servo - gives +230mV. Not bad, assuming this is a CFA with no DC decoupling cap. Servo makes it less than 5mV - you can see it at the first picture.
Bode plot shows wide bandwidth (close to 1MHz at -3db) with excellent phase response(-2.3 degrees @ 20KHz). Fast one.
Square response - not bad, but there is some overshoot, clearly visible at high frequencies, with a couple of fading revolutions before it settles. This is something I don't like and I'm going to investigate it deeper.
The other point that slightly concerns me - thermal stability. I need to make the second heatsink (with the drivers) much smaller. They are barely warm and, I suppose, thermal feedback is not as effective as it could be with the smaller one. Output pairs run at 30-35mA with no signal - rather cold when idle, warming up at higher swing.
THD - not bad, higher order harmonics concern me a bit, however absolute level is low enough and I doubt, this is somehow related to the overshoot, mentioned above. There is an interesting dependency though - frequency wise, minimum is at 5-10KHz, slightly increasing towards the lower frequencies, as well as towards the higher ones.
Intermodulation is good.
Did some listening - no surprise, very natural reproduction, solid, balanced, natural. I like it even "as is".
In overall, it works fine, although I'm going to fine-tune it a bit during the nearest days.
Good ideas are welcome 😉
Valery
Found the "sweet spot" yet? :bullseye:
Well, I have adjusted compensation, so that I get decent squares, but now the problem is - as soon as signal frequency exceeds 200KHz, the drivers and outputs heat-up significantly, and around 700-800KHz I get shoot-through (both output shoulders are open). OPS seems to be too slow...
Killed some outputs 🙁
Do you think output transistor for CFP must be fast transistor (high fT) or it happen only on CFA topology?
Builder thimios fried his 21193/4's with the first CFA. 🙁
He uses 35mhz Sanken's now - says they are the "champs". They survive
cooked zoble's and all. 😱
BTW ... Nice build ,Valery.
PS - this would happen on VFA/CFA , EF3 or CFP. The MJL's are only good for 220pF compensated
"elliot sound" sub amps.
OS
The funny thing - I'm testing with no output transistors now (and no load except NFB, which is ok for these 2 pairs of drivers).
Giving it 2KHz square, 13.4V amplitude at the output - excellent waveform, no problem. Drivers are cold. Half an hour in this state - still cold.
Increasing the frequency to 200-500KHz (same amplitude). Within a minute the drivers get hot. No oscillation or other artifacts on the scope. How is it possible? It's not the case with my VFAs - they run at 500KHz same as at 1KHz.
I agree, MJL21193/21194 are slow (fT = 4MHz), but I have tried NJW0281/0302 with fT = 30MHz... same result.
Well, I don't want to connect the output transistors until I make the drivers cold enough at 200KHz...
Very interesting experience :wiz:
