Cool simple "clean" CFA
OK, here comes the layout...
8.5 x 3 inch, double-sided. Not really simple any more 🙂
However - still pretty cool 😉
Placing the order tomorrow... takes about a week to produce.
And then we'll see... :violin:
P.S. Big ones are actually under the board - 3D renderer just can't show them the right way 🙂 Anyway, gives an impression.
Give us the pdf for home etching.🙂
PDFs
Hi Thimios,
Here go the PDFs in the following order:
1) Top traces;
2) Bottom traces;
3) Top silk.
I did not mirror anything, so let me know is you need more "views" 😉
Valery
OK, just checked the parameters, for 63V rails:
R5, R8 = 63K
R38, R39 = 8.2K
All the rest is perfectly fine - no adjustments required.
Overcurrrent sensing - you're right, however, the PCB is rather packed. In a few other designs I just soldered a 2-pin plug right on top of the big resistors 🙂
Although, I will think where to place it in the refined version of the PCB...
R5, R8 = 63K
R38, R39 = 8.2K
Yes that board does look kind of full. Thanks.
Thimios, wait! Jeff's question has inspired one good idea 🙂 I wanted to avoid CCSs for the input pair, but using them will make the amp more tolerant to the rails variation / fluctuation. I have found an elegant way of implementing them.
Schematic and PCB will be slightly updated! 😉
Just a very little bit less (6 parts added). But now it's virtually rail voltage independent 😉
At least in the range +/-45V to +/-70V no adjustments required.
It's also more tolerant to rail "sagging" caused by high power consumption or mains fluctuations :up:
Version 02
Here goes v02.
I have also added the "BIAS" plug for overcurrent sensor - in the middle of PCB. Size is the same, just "cleaned up" some space 🙂
Have fun! :spin:
  • 03-CFA-CFP-02-PCB-Silk.pdf
  • 02-CFA-CFP-02-PCB-Bot.pdf
  • 01-CFA-CFP-02-PCB-Top.pdf
Slowly but surely
Working hard here 😀
Very close to testing. Arranging appropriate local heatsinks, changing the PSU on my test bench, so... most likely - tomorrow 😉
