I have found the same sort of measurement with other IC's, so it is consistent with prediction.
You might like to try better IC's 😉
Just a brief measurement of loaded ADA4898 (100 ohm + 50 ohm), schematics is in the plot. Please compare with Mooly's 4562 (and do not forget to read Y axis).
Now that is unfair, PMA. People use what they have or what is available at the time of design. The AD part looks good, but I have never seen one, even as a sample. OPPO uses the 4562 extensively, as well as many other high end designers. Let's start here first. It is more widely used.
Jesus, John, that's plain ridiculous. Here we are, asking an op amp to do what it's not designed to do, and then we add insult to injury by using whatever happens to be at hand?
What if the nearest thing they have is a 741?
I would have thought the very first thing anyone starting out in DIY should learn is how to select parts for their role in the whole circuit, not grab what's nearest to them.
Or use it just because it's popular. The King of popularity is the 741.
I have used 10 pairs of them in parallel in my low noise amplifier for measurements (0.1Hz - 1MHz, 220pV/sqrtHz)
and quite a few left over for some amplifiers more, so if you cannot use digikey
< Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps | Integrierte Schaltungen (ICs) | DigiKey >
for whatever reason, I would be willing to send you a few.
regards, Gerhard
Can't someone set up a streaming webserver that runs a script to play files randomly and takes descriptions from listeners? I think this would be make it so everyone is taking the same test with the same protocol.
Heck, it could even be a blog. Like an interactive blog with new tests every week or so. I think that would be genuinely positive for the audio community.
Yeah. Imagine that, choosing an appropriate part for a specified task. Crazy! Unfair! Horrible!
You should indeed be terribly offended at Pavel's use of actual engineering.
SY, your replies are hilarious! :rofl:
They're partly what keeps me following this thread.
I find it amusing that Mr. Curl hasn't heard of the ADA4898-1/2 before. A simple Google search will turn up many good op-amps that apparently "aren't fair" because OPPO Digital and other designers don't use them.
Since he hasn't named any of the op-amps he prefers, I'm going to assume that they're run-of-the-mill devices that other designer prefer as well.
He did say 200kHz so being generous and say you only look at the first two harmonics that's a 600kHz noise BW. -140dB at 7V rms in 600kHz is about .9nV/rt-Hz so now the real part of the impedance of all the frequency generating components must be <50 Ohms. For fixed frequency oscillators I think only Baxendall's passive L/C post filtering could do this though I shudder to think of doing it at 50 Ohm's
Thanks... it then seems within the realm of possibility. David just stated his needs - specs - in the Equip & Tools/Low Distortion Audio range Osc/lines #4053 and 4058.
-RNMarsh
A comparable part that I do use is the LME49990 for the front end of the JC-3 phono stage. I could have used the AD797, but I found it too expensive when other parts of the same quality were available.
I have designed 2 audio products with the AD825. I like that part a lot. The ADA4898-1 looks good, but the design is in production and I don't see any advantage in changing to it.
The measurement that I have shown yesterday was to illustrate that we have a choice of some opamps that are able to drive difficult loads. But it was affected by the resolution of the direct method.
Today, I would like to show a measurement of ADA4898, loaded with 150 ohm, at 1Vrms, with a notch filter and different HW. I am able to measure much lower distortion then. As you can see, behaviour of ADA4898 at 1Vrms/150 ohm is perfect. Unfortunately, I cannot get more amplitude from this method.
Correction to filter frequency response is to be done, so 2H result is in fact 11dB worse and 3H result is 6dB worse. Even so it is perfect.
Why my choice was ADA4898, about 4 years ago:
Ultralow noise 0.9 nV/√Hz, 2.4 pA/√Hz, 1.2 nV/√Hz @ 10 Hz
Wide supply voltage range: ±5 V to ±16 V
High speed −3 dB bandwidth: 65 MHz (G = +1)
Slew rate: 55 V/μs
Unity gain stable
Low input offset voltage: 150 μV maximum
Low input offset voltage drift: 1 μV/°C
Low input bias current: −0.1 μA
Low input bias current drift: 2 nA/°C
Supply current: 8 mA
Many opamps may be googled, but not many with such low noise, high speed, low distortion and high output drive capability - and perfect sound.
Good job, AD engineers.
Edit: I am adding one at beter Y resolution, same conditions.
Any comments? You guys just have to make a choice of the part that fits to your application, not to overload the improper (unsuitable) part above its limits. As far as I remember I have recommended the ADA4898 at least 5 - 10 time here - without anyone interested.
It is a fantastic IC but IIRC it's only available in SOIC - that's why I ended up going with the AD797 for my new preamp.
The ADA4898 is about 1 dB quieter than the 797 as well in the 700 to 2.5 k Ohm source resistance range.
