Hmm.. I was worried this might happen. I had to change the certificate of the software as it expired.
Can you try installing it as a fresh installation. I.e. uninstall the software completely then go to Leonard audio.co.UK and do a fresh install.
If i start TransmissionLine i instantly get:
Code:
System.ArgumentException: Invalid Parameter.
bei System.Drawing.Bitmap..ctor(Int32 width, Int32 height, PixelFormat format)
bei System.Drawing.Bitmap..ctor(Int32 width, Int32 height)
bei TransmissionLine.myGraphClass.DrawAxisFunction(Int32 DisplayWidth, Int32 DisplayHeight)
bei TransmissionLine.myGraphClass.DrawAxis(Int32 DisplayWidth, Int32 DisplayHeight)
bei TransmissionLine.Form1.DrawGraphAxis()
bei TransmissionLine.Form1.SetupGraphs()
bei TransmissionLine.Form1.Form1_Load(Object sender, EventArgs e)
bei System.EventHandler.Invoke(Object sender, EventArgs e)
bei System.Windows.Forms.Form.OnLoad(EventArgs e)
bei System.Windows.Forms.Form.OnCreateControl()
bei System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
bei System.Windows.Forms.Control.CreateControl()
bei System.Windows.Forms.Control.WmShowWindow(Message& m)
bei System.Windows.Forms.Control.WndProc(Message& m)
bei System.Windows.Forms.ScrollableControl.WndProc(Message& m)
bei System.Windows.Forms.ContainerControl.WndProc(Message& m)
bei System.Windows.Forms.Form.WmShowWindow(Message& m)
bei System.Windows.Forms.Form.WndProc(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bei System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bei System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I have been using the Transmission Line software with no problems for about a year.
Today when I tried to open it I got the same Microsoft.Net Framework unhandled exception error as theKenDo posted.
I tried deleting and reinstalling the program twice but still get the same error message and the program wont start. The only thing that has changed since I used it successfully is the installation of Windows updates.
Can anyone help?
Can anyone help?
The version listed is Microsoft.NET 4.5.50938.
The last listed update for Microsoft.NET was a security update about four weeks ago and I am almost certain I have used the program since then. Could another windows update affect the operation?
Hmm this is quite strange. How did you go about deleting the program. Did you you uninstall it from add\remove programs in the control panel?
Strange indeed. I did uninstall twice yesterday from add/remove programs in the control panel.
But I just uninstalled and reinstalled for a third time and it now works!!
Is it possible to simulate a TQWT (basically a transmissionline but with different start and end area with a open tube (like in bass reflex) like this: http://www.lautsprecherbau.de/design/stories/Artikel/2011/Januar/AX_TQWTHolly/ax_8tqwt_holly_26.jpg ) but with the bass reflex opening at a variable position not just at the end?
Im not sure of the correct acronym but its an expanding (positive taper) mass loaded transmission line.
Have built these using LATL
Is it possible to vary the position compared to the length of the line of the bass reflex tube?
Have a look at pages 20 and 21 of the help file. I shows how to split the enclosure and then add a port. If you then click to select the right hand element you can drag the centre line and the port to any position.
Various places really. I did a degree in a related subject and the very first iteration of this software was my dissertation.
I learnt a lot from acoustic engineering textbooks and also found some web resources quite useful.
I'm an acoustic engineer by day too, so that helps!
Hey guys.
I have read the help docs but I can't seem to work out how to add a second driver, is it possible?
Cheers for the great software Schmeet.
Dean
Dean
- Design & Build
- Software Tools
- Transmission Line Modelling Software
