Current drive for Loudspeakers
It looks like transconductanc , the feedback is coming from the current going thru r7. Since it's a transconductance Amp the voltage out will look funny, (Distorted) but that dosen't matter, it's the curent (out) thru the speAker that should be the same as the input signal. Thus transconductance. I out= A Vin. Scope the voltag at r7.
My test load is a 10 ohm resistor. There should be no distortion.
Do you have a schematic?
Here is a link to the Chinese supplier
ºãÁ÷ÐÍTDA7294¹¦·ÅPCB¿Õ°å-ÌÔ±¦Íø
I scoped the shunt resistor. Horrible crossover distortion at 20 Hz. I am suspecting the diodes are in the feedback path and are causing the distortion.
here is a couple of circuits I found on the web...
I am afraid that nothing beats this simplicity by Meriläinen:
This is the heart of all of the three schematics posted above.
There is a problem with this topology. It is sensitive the opamp input offset. I wrapped this around a power amp and it causes the output to stick to one of the power rails.
Schematic #3 above uses a servo to correct this problem. I need DC coupling and DC amplification so cannot tolerate the servo to 0 volts DC. Instead, adding an adjustment at the opamp input to re-center the input to 0 seems to be in order.
I think this 1995 Ian Hegglun's amp might be interesting as a lab instrument
with good DC stability eve, without input cap.
It could be adapted to have negative current feedback so as to behave as a transconductance amp.
Hello Forr
Can you post or link a higher resolution version?
Here it is. I hope it will not be considered as author's rights infringement.
I have a great admiration for all Ian Hegglun's works.
I never heard of someone having built this amp.
I hope to do it one day myself as it it seems very interesting for experimental purposes and it is quite simple.
Thanks for this, manually tracing was a pain so I didn't get to the power supply and protection circuits.
I received an Otimus 1971. Checking it out before the surgery. It puts out about 16V AC into 10 ohms before clipping. Noticeable 1V RMS output droop at 20 kHz. Nice low freq response, no droop at 2 Hz.
I will open it up and start preparing it for the switch to transconductance mode per your schematic.
Do you have any pictures of the inside after your mod?
