TPA3116D2 Amp
As promised, spent about an hour listening and comparing the DUG amp to my much modded blue/black amp.
A clear winner? Very difficult, so very little in it. I would think - "aha, there is a difference", swap back and... nope! In the end I think the DUG amp is just that little less grainy, cleaner, evident mostly on vocal pieces. But really, if it was double blind, I doubt I would pick it every time.
To put into context of equipment etc. - speakers are my FH3 cabinets with 4" Tangband drivers (bit less revealing than my MA drivers), autoformer volume control and ES9023 based USB DAC. And, of course, my less than perfect ears.
Main similarities/differences between the 2 amplifiers:
Same transformer
Same PSU tho the blue/black has lower quality caps but more capacitance
Blue/black has WIMA input caps, DUG Sprague PIO
Blue/black has Bourns inductors, DUG has Coilcraft
Other minor differences.
Last of all I put in a YBDZ board, fully modded with Meanwell SMPS PSU - yes, I can tell the difference now. This amp is brighter and harsher tho still not too bad an amp.
Quick pic of set up during comparison, mainly so I can show off some of my kit!
Thank you for the review so I can vicariously enjoy the DUG PBTL before it is built! I have the PCB but no parts and no time. Don't forget that because it is a PBTL monoblock it can drive 2ohm loads up to 80w cleanly. Maybe a speaker that uses a bipole of two 4ohm drivers in parallel would benefit. Or some car audio apps. 2ohm DVC subs. Etc.
I am curious what would happen with Ybdz on linear ps and upgraded inductors now. I am about to order another pair of Ybdz to go with my second miniDSP.
A 220nF 16V ceramic will be closer to 220nF then a 220nF 250V ceramic. Higher voltage rating gives higher capacitance drop.
No
Let me rephrase to make my statement clearer:
A 0.22uF / 250V X5R at 10VDC will be closer to 0.22uF than a 0.22uF / 16V X5R at 10VDC.
The 250V part will exhibit less change in capacitance as the % of applied to rated voltage is less.
10 / 16 = 62.5% of rated voltage
10 / 250 = 4% or rated voltage... Less change in capacitance.
The higher voltage rating is adviced because ceramics also distort, ceramics rated for much higher voltage distort less.
Yes, I am glad we agree that when the capacitance becomes part of the gain equation there is a change in capacitance as a result of variations in applied voltage. This is where the distortion occurs. To minimize distortion we use a higher voltage rated cap so the variation is minimized.
Some people say they are able to hear even these small distortions and will not use any but NPO (COG) ceramics or not use ceramics at all.
But, IMHO, for bootstrap caps it is not that critical.
No
No LOL
In general higher voltage rated ceramic cap has higher capacitance loss at same voltage.
Quote from:
Temp and voltage variation of ceramic caps, or why your 4.7-uF part becomes 0.33 uF
Mark Fortunato - November 26, 2012
"A second interesting point is that, within a package size and ceramic type, the voltage rating of the capacitors seem often to have no effect. I would have expected that using a 25V-rated capacitor at 12V would have less variation than a 16V-rated capacitor under the same bias. Looking at the traces for X5Rs in the 1206 package, we see that the 6.3V-rated part does indeed perform better than its siblings with higher voltage ratings.
If we had looked over a broader range of capacitors, we would have found this behavior to be common. The sample set of capacitors that I was considering do not exhibit this behavior as much as the general population of ceramic capacitors."
To be honest I wasn't really expecting any substantial SQ improvement with the DUG board given almost identical PSU. Having realised some (most?) of the potential of the 3116 with the modding of the blue/black boards and favourable comparison with my Mini Aleph, I decided to build another 3116 to go in my OB system with the MA driver. The DUG board was the obvious choice to get the max out of the chip. Do I need dual mono or 80watts into 2ohm - for this application clearly not. The driver is only 85db so I do need reasonable power but this is countered by the 250hz 2nd order crossover.
So today I will put the DUG amp into my OB system. Simple enough - just have to adjust the relative gain of the main and sub amp on the miniDSP.
Matt, I had previously only replaced 4 of the 8 PS caps with the Panasonic Oscons, and left the other spots open, but after reading your post, I added 4 more. It really is an improvement, especially bass.
Yup, the better bass is for me one of the key features that makes the new Sure tp3110 better than any of my tpa3116 boards. (That, and the "blacker blacks" I believe I am (not) hearing.)
And I wonder if having all that on-board, close-to-chip OSCONs is what helps the bass so much?
Anyone know, is there a "clean" way to add several on-board, DC-coupling OSCONs to a tpa3116 board? What I envision is something like a mini-breadboard, just big enough to fit a row (say three or four) OSCONs right next to each other. I'd leave the leads on one cap long enough to go through the through holes in the (for example) YJBlue board.
In other words, something like a "three-in-one" (or "four-in-one") adapter for having multiple, parallel caps in place of just one.
I was also thinking I could just bend the leads of the caps and solder accordingly to achieve this goal. Then I'd glob the whole assembly in hot glue or something non-conductive to add structural support.
All components on YJblue can be chosen better, decoupling layout can be improved. If you compare drumsolo between modded YJblue and DUGpbtl you can notice difference decoupling layout in first contact of each stroke. That is just ~10mm closer to chip if decoupling ceramics are same values classII as on your modded YJblue.
BTW I can not compare just closer decoupling, for decoupling I have 100nF classI (voltage independent) on DUGboard and 10uF classII. As big elco's I have 2*2200uF KZH 35V per channel. Bass is better then with Oscons, so is treble in my opinion.
Maybe its my ears I need to upgrade - well they are getting on a bit and have seen some abuse.
KZH - are they United Chemi-Con?
What PSU are you using?
From your detailed system description (and the very nice pic) I reckon your ES9023 DAC is a fairly major bottleneck. Upgrade that and perhaps amp differences will become more apparent - the DUG board does include the pin17 mod which was a substantial step up for me.
Chris the PSU might make them seem a bit more similar, too. It does some substantial things even on some of the crappier boards.
That being said, I think maybe abraxalito has somewhat of a point. Although I don't know the details of your DAC. I've got a festih with 1543's for whatever reason... well the PD one that's competitive with ML gear etc.
No LOL
Quote from:
Well, I looked at the site and was totally confused by comparison of apples and oranges and bananas and pears.
So I went to the Murata site and found the graph function.
And compared some things.
Comparing apples to apples was not easy as it offered limited choices.
As it turns out I was not totally correct. (can't possibly say wrong 🙂 )
The graph on the right shows 0805 GRM series of 0.1uF of all 1.35mm thickness with 25V, 50V, and 100V parts.
Very interesting...This graph makes us both wrong. 🙂 (IMHO)
The graph on the left shows that (if you shift for equal start point) the thickness is of more importance for capacitance change than the voltage rating...all other things being equal.
I am glad to have had to look this up.
Thank you.
Doug
DACs! Well the DAC I used to compare this time is not the one I used before in earlier compares and probably not so good as the one in my OB system. My OB system has a Subbu DAC (9023) with dedicated low noise PSU linked via I2S to a Amanero USB interface. May be not top of the line but well respected boards in diyaudio. In perspective of the rest of my system I doubt it is the bottleneck tho maybe my lesser 9023 DAC would be.
I do have a 1543 DAC with PCM2707 USB interface, upgraded clock etc. I built some years back - good in its day tho I must admit I have never actually compared to the Subbu/Amanaero. I kinda see the ES9023 as the modern day 1543.
