2stageEF high performance class AB power amp / 200W8R / 400W4R
Noise of audio amplifiers is usually measured with a 10Hz to 20kHz bandwidth.
A weighting is often used.
So the two figures to use would be 121dB 10Hz to 20kHz
and 127dB A weighting.
But these are very exceptional, making me believe that the measurement bandwidths don't comply with the norm.
I understand A weighting is often presented but only because it is more favourable i.e. it presents a higher number. I am trying to compare this specs of this amplifier with two others:
1. Theta Digital's Citadel (yes, I am a Theta fan)
Unweighted signal to noise ratio >103dB
2. The NC1200 module from Hypex which underpins the Theta Prometheus
(Unweighted, add 2dB for A-weighted)
137dB Pr unbuffered
128dB Pr buffered
112dB 1W 8R unbuffered
103dB 1W 8R buffered
I do not understand the different measurements here.
PS: I'm sure this amp thrashes my nearly 20-year old Krell FPB 200
The psopho looks like what I remember what A weighting should look like.
The "audio filter" seems to have adopted a much steeper roll off than the 80kHz filter.
That would probably account for the 2dB error between these two noise figures.
The 80kHz and 20kHz noise should be 6dB different IF the noise is continuous and flat through the pass band and a bit beyond.
But even taking that 2dB into account these are still exceptional noise figures.
How do they compare to D.Self -96dBu?
-96dBu is the same as 12.7uVac at the output.
For a 200W into 8ohms amplifier with a maximum output of 40Vac, that 12.7uVac is ~ 130dB S/N
I understand A weighting is often presented but only because it is more favourable i.e. it presents a higher number. ..............
Some maufacturers will misuse A weighting this way and conceal the "flat" noise figure.
But that is NOT the reason that Aweighting (and all the others) exist.
A weighting gives a close approximation to how annoying we "hear" the noise.
That is why it exists.
The quote both flat and A is useful to customers.
Of course. :rolleyes: I never argued why it existed. (I could debate your definition of A weighting but that's off-topic.) I merely stated a fact, which you repeated, that often manufacturers only disclose this more favourable headline number.
Now back to my question. As one of my comparables only publishes an unweighted statistic I'm interested in comparing it with Toni's equivalent figure. Is this 121dB or some other number to be calculated?
How do I interpret and compare the figures disclosed by the manufacturer of the NC1200?
I find that equivalent Ein is a useful number for comparison.
Take the flat or A weighted Noise output in µVac
convert to nVac.
Divide by the amplifier gain.
Divide by sqrt(bandwidth)
You have the Ein in nV/root Hertz.
ex.
Self's 12.7uVac *1000 =12700nVac
Gain ~30times and root bandwidth = ~141
converts the 12700 to 3nV/rtHz.
That is quiet. Quieter than a 5534.
Joined 2011
Dear Andrew,
thanks for clarification. My amp has about 20uVac noise at the output A-weighted (input shorted via VP7723D / 600R).
Hope you can help finding link or details about "D.Self -96dBu?".
Unfortunately "diyaudio search" and "google" doesn't find any reference. If it is in one of his books maybe you have a page reference.
Thanks in advance! :)
BR, Toni
Joined 2011
Are the C12 and C13 part of compensation scheme or for some other reason? These
caps appeared around my VAS limiter idea and I cant find a word about them.
And to be pedantic: shouldn't be "Miller: none" at "R28 value" ;) ?
Thanks for bug report. You are right - R28 should be omitted if using "Miller" compensation only. I will submit a corrected version the next days if bom is ready for download.
C12/C13 are part of the compensation scheme. It betters the gain margin.
Joined 2011
... start tuning for lowest SNR with homebrew h-field probe ... need to add some cnc machined mu-metal.
SNR from lab is as low as 125 (A-weighted)
Current SNR is about 110 db (A-weighted)
Picture 3: homebrew h-field probe
Pictures 4 and 5 are showing rectifying spikes. Using the h-field probe it is very easy to find "hum" hotspots. ;)
BR, Toni
