Hi Rudi,
Any chance of adding some "Soft-Power-On PCB" in this run, as found in this thread:
http://www.diyaudio.com/forums/group-buys/187592-3-symasym-23.html#post2920352
When yes, I would like to have 4 of these.
Reason, the trafo below (2x 25V ringkerntransformator 300VA) can be ordered for € 47,43
where this one (2x 25V ringkerntransformator 225VA) has a price of € 62,25
I plan to build dual-mono layout as suggested here:
http://www.diyaudio.com/forums/group-buys/187592-3-symasym-64.html#post3310974
and practiced here:
http://www.diyaudio.com/forums/group-buys/187592-3-symasym-69.html#post3477169
Yea, yea, the heat-sinks shown here are too small, we have been there before 🙂)
So when I order two of the cheaper 2x 25V ringkerntransformator 300VA I need a "Soft-Power-On PCB", to limit the inrush current.
PS. in my previous Post I did forget to add the 1 x 4% paypal costs
Kind regards
Bert
Did you take a look at Schuro?
Hi Rudi,
and practiced here:
Kind regards
Bert
Ask at Badel,
my 400VA Transformer (4x 25 V Secondaries), including Schirmwicklung, Low-Inductance Version, Magnetic shield, cup epoxy moulded was only 65 €s. This is the one I currently use with the standard Birger's Symasym PCBs and is far more then sufficient.
Really quick shipping (around 2 weeks), and absolutely high quality from these guys.
Fabian
I can mail u a picture if u want some reference for Badel, so communication with them goes more quickly ;-)
Edith says: picture from Badel of course, no photograph of my transformer ;-)
Trafo options
meanman1964 and Fabian85,
Both thanks for your hints, however I did not have an issue selecting the transformer (now I have, the Schuro tranformers are tempting)
Schuro sells interesting products for a reasonable price.
Badel at seem to produce to order, so I have to specify the product, that is a bit too much for me.
Schuro and ringkerntrafo.nl are webshops, where ringkerntrafo.nl gives you the full specification of the product, where Schuro does not have specs for the transformers online.
I have ordered stuff from ringkerntrafo.nl before and they ship fast (in the netherlands within two days)
Edit: I did remove the links to Schuro and Badel
Bert
Bert
Hello Rudi,
I'm really happy that I can finally participate in a group buy.
As you stated that the ordering will end Monday 11th we are really
close to the end.
I would like to participate and order :
2 x Black Beauty PCB
2 x 2 Pairs of NJW0281/NJW0302
2 x 2 x 0R22 Resistor
2 x MKT1822/10µ + MKT1837 10nF
1 x Shipping to Germany
1 x Paypal fees
Additionally I would favour to have the PCBs cut into pieces.
It's ok for me to use Paypal to pay for the parts.
Am I right that this order is sufficient to build a stereo version of the amp (with the rest of the parts on the BoM) ?
Is there any estimation for the time of delivery ?
Best regards,
TrustinTech
close to the end.
1 x Paypal fees
Best regards,
TrustinTech
Hello Rudi,
close to the end.
1 x Paypal fees
Best regards,
TrustinTech
Besides the parts of the BoM and the one's you ordered you will need matched 2SK170BL and a transformer / transformers.
Gentlemen, this group-buy is closed now and I will not accept any further requests.
Find attached the final order list.
I could reduce the price for nearly every component, since we have reached a lower scale of discount (>25 of each).
I ask you to transfer the the final amount (given in column TOTAL; the curreny is € !) to my PAYPAL account: RRozek@t-online.de.
I will order the components, after I have received all of your transfers.
It normally takes about 4 weeks, until I will receive the etched PCBs.
I will then send you all of the ordered components.
I will send to you all a Builder's Guide (written in English), drill template, ... vial EMail.
Please make sure that your home- and EMail-address matches the one that you have stored in the PAYPAL form.
I revised the BoM of the SYMASYM- / Speaker Protect- section.
Here is it:
https://secure.reichelt.de/index.html?&ACTION=20&AWKID=940926&PROVID=2084
The BoM of the PSU-section did not change:
https://secure.reichelt.de/index.html?&ACTION=20&AWKID=939684&PROVID=2084
Please do not blame it on me, if the BoMs are not 100% complete (I have done my best though!).
The BoM does not include:
- transformer
- heatsinks
- input differential transistors (my advice is to either use 2SK170, MPSA18 or BC550C)
I will now wait for your money transfers.
Best regards - Rudi_Ratlos
Here is it:
- transformer
- heatsinks
Rudi, thank you very much for your work! Can't wait to get my hands on it!
By the way: the numbers and values of the resistor link you gave me via PN did not change? So if its ok for you, can i post it here for other people who, like me, prefer to use higher quality resistors like Vishay / PRP / Takman. Since they are no "few cent parts" like the Reichelt resistors, it is a nice to know orientation how many one would have to order.
Fabian
Fabian
Hi Rudi,
thank you very much for your effort and time to make this group buy happen!!
Money transferred via Paypal🙂
All the best wishes,
Michael
Michael
Gentlemen, Watchtmouse, WillNamennichtnennen:
I do currently have no Soft-Power-On PCBs at hand.
But I can order 10pcs. of the one shown in the attached image.
The size of the PCB is 90 x 69mm; its colour is green; its price is 4.50€ per PCB.
It can be used for 230VAC/50Hz (you need an EI30-1 transformer / 12VAC) as well as for 115VAC/60Hz (you need the TAMURA 2FD-212).
The schematic uses a LM555 timer module and 2 relays.
The top relay is closed as soon as the 7812 voltage regulator shows 12VDC on its output. At this time the current is limited by 2 NTCs (the shown values are a proposal).
As soon as the delay time (determined by the 100K resistor and 10µF capacitor - giving a delay of about 1.1sec) has expired, the bottom relay will close, bypass the NTCs and the mains current flows unhindered.
Best regards - Rudi
Best regards - Rudi
Would you recommend it over the PCBs from the Analog-Forum community? The Green one with the relay, 1 NTC and without any transformer? Is it any better? 🙂
Hi Rudi I dont need a soft-power-on pcb anymore. I'm in contact with Badel to buy a transformer similar Tod Fabian's. There you can also buy transformers with a soft-power-on function, which I want to use.
@Fabian, WillNamennichtnennen, ...: if you are planning to buy a 400VA/4x25VAC transformer from BADEL, as specified by customer, with all extras ("Schickimicki"), I would like and join you and buy one myself!
Maybe one of you can start a "transformer-groupbuy" for the BADEL's transformer (here in this thread).
The way I have layouted this SYMASYM "cries" for a transformer like this!
Best regards - Rudi
P.S.: Nobody needs a Soft-Power-On PCB unless the consumed power is significantly higher han 500VA.
P.P.S.: A "green" forum's name means: "Money received".
Best regards - Rudi
Gentlemen:
I can choose between a "brilliant black" - and "matt black" - PCB-surface.
Which one shall I take?
Rudi
Rudi
I prefer the matt black.
Fabi already has the transformer and I think the organisation of a groupbuy would be too much for me. What I can do is posting the schematic drawing oft the transformer with its specifications.
- Group Buys
- TO-3 SYMASYM
