I have an SVS sub model 20-39PC-Plus which has failed. It powers up but no output. I'm looking for schematics and any relevant info on the Indigo boards in it, namely:
630096 Rev 0
630126 Rev 0
630127 Rev 0
640022 Rev 1
650027 Rev 2
SVS have been no help, and Indigo itself appears to have been sold to the Chinese company Sonovox and proprietary rights to the designs get in the way.
I was able to follow a bit of the layout by comparing to the Klipsch Promedia information compiled by Dale Thomson in Klipsch Promedia V.2-400, V4.1, V2.1, And V5.1 Amplifier Repair
Power supply voltages look good but the signal is lost somewhere. Without reverse engineering the whole unit...🙁
Any help appreciated.
Thanks, Don Whyte
630096 Rev 0
630126 Rev 0
630127 Rev 0
640022 Rev 1
650027 Rev 2
Thanks, Don Whyte
Hi Don, any luck? I have an SVS- 20-39PCi that has been hit by lightning. Found what I think is a bad cap. Indigo Board is 600109 Rev 6... No luck either. Do you know if the boards are similiar. I see a blown part on it that is what I think to be a high voltage cap (C417). I am looking for someone who has a picture of the cap that maybe I can get the value for it? Any chance these boards are similiar?
https://drive.google.com/file/d/0B9C1vDEkISfJS212WUJlS2dYTWM/edit?usp=sharing
https://drive.google.com/file/d/0B9C1vDEkISfJUXZ4NjNoR1l3TGs/edit?usp=sharing
https://drive.google.com/file/d/0B9C1vDEkISfJZUhzalhyZGVFU28/edit?usp=sharing
https://drive.google.com/file/d/0B9C1vDEkISfJb2hlTWl4eFRlWXc/edit?usp=sharing
The board you have is not similar to any in my unit. I would think that if hit by lightning many other components would be ruined also.
Hi, I'm having a similar problem with a Indigo Bash 300W sub amplifier from a Tannoy TS10. It has the following boards;
600109
650038
630139
630137
660037
If anyone has schematics for these boards please let me know.
Fused
600109
650038
630139
630137
660037
Fused
@ fbarickm c417 is rated at 3300pF.
I also have the service manual for the Indigo Bash 300W (Tonnoy Spec ts10)
Do you mind sending me a copy? My TS10 just quit working and I tried to get schematics without success. 🙁
Thanks a bunch!!! 😀
D
I also have a defective Tannoy TS10. The symptom is low audio... It looks like capacitor C412 (1000uF, 100V) on the PS board is swollen. The PS board is putting out about 8 volts DC to what looks like the amplifier board, independent of level. Any chance I can get a hold of the SM?
Thanks!
Thanks!
I too have Tannoy TS10 with a defective power supply (indigo 600109). May I request a copy of that service manual? It would me MUCH appreciated!
I've also a Tannoy TS10 with a defective power supply. Could you send me a copy of the service manual also? Many thanks!
Hey, Me too! My Tannoy TS8 is behaving very much like these others and I would sure like a schematic. I have the same bunch of boards as Fusedbrain. Cap417 looks OK on mine, and is a different type: Blue blob, made byWmeC, and doesn't look burnt or bulging.........Thanks!
I have another Tannoy TS10 with blown power supply. I would love a copy of the schematic, can anyone oblige?
Tannoyfreak, Mine is exactly like yours. Did you ever figure it out? My blue cap shows open circuit but I'm not sure if it is suppose to do that until a certain voltage is achieved. It looks good on the outside.
tannoy bash service manual
hi I'm new to on here but desperately need schematics for the indigo bash power supply board found in tannoy subwoofers board number is 600109 .i believe its found in the tannoy ts 10 but mine is an arena subwoofer( think its300watt) i sa that some one hd a copy of the service manual any info would be appreciated🙂🙂@ fbarickm c417 is rated at 3300pF.
Thanks a bunch!!! 😀
D
Pleeeeaaasee... 😀
Greetings all, I am also looking for the service manual or schematics for the Tannoy TS10, or the iNDiGO BASH 300, board 600109, any help would be much appreciated!!!
Thanks in advance,
Ian Mac
Thanks in advance,
Ian Mac
Frad, thank you for sharing! 😀
- Subwoofers
- SVS sub Indigo board repair
