just ordered some here:
http://www.diyfidelity.com.au/product_info.php?cPath=0_33&products_id=32
Whats the price?
Whats the price?
just tried them, cannot get the full output voltage How come? input is 10k, output is max 7,2k so there is a loss at putting !v in and getting 0.72V out. Anyone? See this thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=42703&pagenumber=4
So here's mine - sort of a badly needed panic volume control between my DAW and monitors. Parts are RS 100K stereo pot, 2 14.75K resistors (closest I had), 2 RS Mini-Jack connectors and courtesy of Hobby Lobby, a 50 cent box & a 99 cent knob. No silver wiring so I don't think I broke $10 on this project.
Bgt said:just tried them, cannot get the full output voltage How come? input is 10k, output is max 7,2k so there is a loss at putting !v in and getting 0.72V out. Anyone? See this thread:
23 steps instead of 24. But how to calculate a 10k 23 step att.?
Quick question
I just built this setup using the 100K audio taper Alphas from Radio Shack with 22K resistors running in parallel. everything works great but I am not getting much in the way of volume... There is no sounds through he amp up until around 3/4 turn of the pot... Any ideas?
thanks.
D
thanks.
D
Can someone please post or email me a close up picture of the radshack passive preamp. I want to build one but can't read schematics. Some close up pictures would really help. Thanks.
I'm in the same boat Justpoor, I really like the one FBJ did!! I would love some more details about it
I talk to someone about my passive preamp and he starts talking about phase difference between frequency. I don't really understand. Is this a real problem or iit is just some electric concern?
I built my passive preamp based on this schema:
http://www.diyaudio.com/forums/showthread.php?postid=20694#post20694
The preamp sit between monica (from diyparadise) (without the gain stage) and a gainclone
passive pre
hi
just built a passive pre haller design using 100k alps pot sounding very good, i would now like to introduce a 6 way 2 pole rotary switch could anyone give me a step by step guide on how to do this
thanks
hi
thanks
Output impedance of my source is 75ohm, input impedance of my power amps is 100K. What Alps pot, 10K, 50K, 100K and wich resistor should i use? Thanks a lot!
Today i tried a 10k log alps with 10k resistor (shunt mode) sound is realy nice but almost no bass🙁
Next experiment was a 10k linear alps in normal mode, no series resistor, know i have realy nice bass.
I am confused now what i should do. Come on guys lead me in the right direction.
What is the value of the output coupling capacitor in your source? How low do you want your bass to go?
- General Interest
- Everything Else
- Passive Preamp
