QUAD 909 Clone
It's just showing how critical component choice can be sometimes ?
At least it works so that it can be measured without smoking.
Maybe, maybe not... its a clone, not an original and so something may have got lost in translation.
The OPA604 should be OK but it can draw up to 7ma and so the 10k needs to be nearer 3k9 to cover that. Everything is as it is for a reason, 10k and the TLC type opamp. Any component change needs following through to make sure it will be OK.
It won't be the opamp. That can't do anything with it configured as an integrator. If the boards are truly identical then maybe its worth swapping the boards and seeing if the problem transfers to the good board, and if so indicating a wiring issue.
These things are difficult to diagnose at a distance.
OK. Well don't overlook or assume anything. Check visually that each part and device type number is identical between boards. Its worth doing a DC check of all the operating points, in particular making sure that current flows are similar (volt drops across resistors) around the front end. Are the coils a bit of an unknown ? Are they fitted identically with regard to orientation, although not polarity sensitive they are not symmetrical with regard to how they are wound. So fit them so the windings are the same on each channel.
I've returned to the 1.0mm coils in order to eliminate that unknown.
The opamp just provides a DC bias voltage the value of which changes slightly to keep the offset at zero. You should see zero oscillation on its output.
Ignoring the DC output offset can the amp be run without the IC ?
I am seeing oscillation at its output but that might be being reflected back through R5.
That was my rational behind fitting 100nF bypass to IC1.
Yes you can run the amp with fixed bias to test. Measure the DC voltage at the opamp output and then rig up a pot to give a similar voltage at the wiper and feed that into R5 (having removed the opamp).
(Don't connect speakers while you initially set it)
