Retro Amp 50W Single Supply
Help on AMP
Ok here's the corrected one....
Hello Wiljj78
Can I used 2n3055 instead 2n3773 and bd 139 instead MJE340 any other changes in circuit have to make to work with following supply. I have 22 0 22 AC 1.2A transformer. can it works and how many watts in 8ohm load with this supply.
1.2A is a pretty small transformer - It will probably drop from +/-30V all the way to +/-22V under load (about 25 watts RMS). That will make it a bit safer to use 3055's.
When a transformer is loaded that heavily, the leakage reactance will drop the DC down from the peak voltage to the average, which is close to the RMS. And that's even before considering resistive losses. Many a cheap stereo was built this way - especially from the era from where this circuit came.
ok, I'm going to do tonight
regards Olaf
Hi, here are the files. Sorry, I made this layout only to print. The components are not named. Basic for the layout comes from Willy B. Cerna from post #79. Please look at the pictures there and check the component values and the polarity of the capacitors. May be you will find the better layout there 🙂.
regards Olaf
regards Olaf
Thank you sir...
