Yet another Volume controlers and source selections
Hi guys. A simple yet bugging question. I'm trying to get inputs switched using a rotary encoder.
now I've searched the Bascom help page regarding encoders. However the explanation there is a bit unclear.
From what I understand, I need two pins, set as inputs and with activated pull-up resistors. That's easy to code. However Içan't figure out the encoders code.
Is there a simple example on how to implement an encoder into the code?
Venci
Disabled Account
Joined 2010
Tibi,
I have an problem with the remote, everything works fine
I use led light in our home sometimes the remote goes automatically
up without push the buttons of the remote
It seems that the led light in my home gives an reaction on the remote censor
is there a way to blok this
Thx
Hello my self amit from india i have make TDA7439 + ATmega8 preamp circuit (download and make) related link :--
http://milosz.muzyczki.eu/elektronika/lm3886tf/lm3886tf.html
all circuit work but Remote is not working you are says (Atmega IR remote transmitter that is 100% compatible with any project) so please say it is possible to match this circuit please answer me and send you (Atmega IR remote transmitter that is 100% compatible with any project HEX AND CIRCUIT ) my email ID is :- amendhi2@gmail.com
I have waiting you reply
Regards..
hi,
Did you connect the IR-led correct ?
there are differnt IR-led pinouts !!!
z5500 -replace
hello.
I'm new on this forum.sunt interested in this project since Logitech Z5500 controller has failed. want to reuse Z5500 with atmel and 2x20 display.
I would like to tell me which version is suitable for display hex 2x20. and PCB layout. I want to use the control with TDA 7318. original.jpeg
Have been using a stock vicol r2r controller for over 3 years and i am really happy, one of the best things that i have introduced to my system.
Now its time to update my firmware as i am running one of the 1st versions. I got myself a usbtiny and have been reading through the instructions and this thread. First question, should usbtiny give power to the vicol board or not? Other than the 6pin header in the vicol side do i have to connect anything else or place a jumper anywhere in the vicol side before starting the process?
cheers
cheers
Either way give power or not are OK as long as you do not have 2 power source both powered on.
But I suggest to set usbtiny to not power the board and to power R2r controller from his usual power source (you know there is a jumper for that on usbtiny).
For anything else fell free to ask.
hello.
I would like to tell me which version is suitable for display hex 2x20. and PCB layout. I want to use the control with TDA 7318. View attachment 420065
Look in the romanian forum : Forumul Electronistilor the organized links to schematics and firmware version.
Anyway for that schematic there are some version of firmware ( but with switch button and not with encoder as in Logitech ) i have attached here tda_7328_ctrl_v13
Also there is a schematic and a firmware with atmega8 micro if you search there.
  • 7318_ctrl_v13.zip
Did the update, everything went very smooth. Great firmware version, many thanks danzup, excellent stuff
