MJL4281/4302 are fine to use
Hi Terry,
I have checked the datasheets and ran a simulation - it will be fine to use MJL4281/4302. No problem in terms of SOA, may be slightly higher Cob, however it will be ok - no significant difference.
Even the pins are in the same order B-C-E, so no PCB change required.
If you decide to build - let me know, I will give you the latest PCB outline in the format you need.
Valery
Hi Valery,
Does this amp require Sankens? Will it work well with MJL4281/4302?
thanks, Terry
Hi Terry,
Valery
Hi Carlos & Hugh
I had a go at building the design in post #1 a couple of weekends ago. Unfortunately I was a bit optimistic thinking I could do this on veroboard and the result was not so good...
When I get a bit more time I'll have a go at laying it out in Eagle and look at getting some boards made at a board house.
Hopefully somebody with the skill and equipment to etch boards at home will give this a go in the meantime!
Cheers
Christian
Cheers
Christian
Hi Valery,Hi Terry,
Valery
If you have Gerbers that would be best. If not, a printable foil pattern would work. I would like to give it a try.
Hi Christian,
I asked Juan to give the layout a try and he said he would when he had time. I know he is very busy.
Blessings, Terry
Documentation
Terry, here are the Gerbers and just in case - final PDFs along with schematic and BOM.
Valery
Hi Valery,
Hi Christian,
Blessings, Terry
Valery
Hi Valery,
That's great! I am waiting on some Gerbers from Jason and I will send of to have these made. I have to have excess boards made because of minimum order requirements. Do you mind if I sell the excess?
Also, if you make Gerbers for the Tube IPS you are designing I would like to have those too.
Thanks, Terry
Thanks, Terry
Hi Valery,
Thanks, Terry
Terry, no problem if you sell the excess boards.
Please check the Gerbers somehow - I normally use P-CAD ASCII format for ordering, so I'm sure P-CAD files are ok, however I never used Gerbers, so I'm just not sure they contain all necessary layers, etc. (though I exported all possible Gerber components).
Sure, I will share the Tube IPS layout - coming soon 😉
Valery
Valery
Can Q17 and Q18 be replaced with onsemi to-220 driver transistors MJE15032/33?
also LF411 to tl071?
reg
prasi
reg
prasi
Hi Prasi,
Yes, MJE15032/33 and TL071 will be fine.
Valery
Hi Prasi,
Valery
Thanks a lot Valery!
reg
prasi
- Some people loves a challenge ....
