The making of: The Two Towers (a 25 driver Full Range line array)
Just got word that my CNC plans are out the window. Now I need to find a new way to get what I want. I will have my aluminium sheets back next weekend.
I might revert back to water yet cutting and doing the rest with my router table.
Thought (always a dangerous thing!)....
Could you not make the front baffle by laminating with say 1mm aluminium either side of ply?
Also remember if a budget is in mind you can get some rub collars for your router and make your own template out of plywood to clamp on to the baffle instead of buying a circle jig .... just make your template hole bigger to compensate for the rub 1/2 collar and to the whole measurement of bit diameter....
The plasti dip will peel sure enough but is not that durable , personaly I would sand my towers very smooth and coat them with plastic Resin ( fiber glass resin) could tint this any color you would like and eliminate the fiberglass cost. Here's another Idea after sanding smooth coat the towers with water based veneer glue ( Better Bond ) this a catalyst drying rock hard its thick enough to fill cracks roll this on with a foam veneer roller or touchup roller found at your hardware store. I coat my Line arrays with this just to seal off the MDF and to give me an ultra slick finish to apply my black ash veneer peel & stick. If you don't want to use veneer you could spray paint over this.....
2 coats of Polyester Resin, 1st coat 'un-waxed' so it remains tacky the coat 2 has 'wax' added - wax in styrene being a leveling agent and makes the resin 'cook' it's self).
This 2nd coat is known to surfers as a 'Hot Coat'...... you can sand it real nice then do whatever you want to it, usually a 'Gloss' finish.
You can tint it ANY colour you want as well 🙂
Then gloss / polish over that.
This boards finish is very thin (about 2.5mm), with 2x layers of 100g 'S' glass tint laminated / hotcoat / 'Taupo Gloss' resin.
Looks liquid in the flesh.
You can also 'Glass Polish'....... thats Really tricky / hard work.
That sounds like allot of work and high cost
Quite true, but then you get what you pay for, money, time or both.
That board is 8ft long, resin (Silmar lam / Taupo gloss), cat and wax, paper and polish compound = 60 euro's
And about 5 times that to pay me to do it - didnt charge him for the hours I spent staring at it, squinting hard from every angle for hours on end under the lights...... countless test tints on scrap to get the colour 'Just so' OR the resin pin stripes.
The customer said 'Really go for it D...... blow us away.'
That was my first attempt at 'Tint 'n' Gloss' and took me about 3 weeks.
I would say that wesayso has ample skill to do a similar (less the glass fibre) to get some where close to the Fenix board's finish - also has the advantage of the shape being 'strait'.
Edit
(Path of least resistance does come into play though, as does the smell of Poly resin......)
I tried polyester resin on wooden boards. It doesn't stick very well. Works great with foam and fiberglass, but not so with wood.
For wood, epoxy is better. Harder to get bubble-free, but stick better to wood. Unfortunately, epoxy is a little more expensive than polyester resin.
Surface prep is everything, wood boards surfaces are almost totally 'end fiber' - these lift when wetted and will muck up almost any finish, laminated or not.
Cellulose aircraft dope does the trick - makes the fibers stiff = Stable 😉
Test on test pieces as always.
Hmmm not sure where to get "dope" in my corner of the world. I hope it's easier to get in the Netherlands.
I do like the idea of plasti-dip... but not on these gorgeous two towers. Might work great on a subwoofer box, but the Towers look amazing in clear coat.
as I recall, dope was basically lacquer
Silk and dope was the dominant way to use as fabric cover on aircraft, full-size and models where the structure was open and covered with fabric.
An agent was brushed on the structure, fabric applied over which again was "doped" in order to activate the agent creating a bond. The dope also sealed the fabric allowing paint to be applied IIRC 🙂
Usually with model aircraft the balsa structure is 'doped' first, sanding lightly between the 2 or 3 coats, this stiffens the grain so the tissue / nylon / silk dont lift.
Full size covering is cotton fabric that is actually held onto the structure with stitching over the leading edge, ribs and trailing edge and then covered with pinked tapes.
(I've done this at 1/5th scale on a Sopwith Pup and a Pou du Ciel @ 1/3rd scale - utter nightmare!)
We Aeromodellers also use a 'Sanding Sealer' - I've never bothered to find out whats in the stuff one buys in a tin. It can be made by adding talcum powder to plain dope, this dries with a slightly milky blush.
FYI: 'Clear' dope was dropped as a finish in the full size world in favour of 'Aluminium' dope or the horrid 'Red' dope - both to combat UV aging.
Pics please (PM)
Ditto on the talcum. Fine ground gypsum and similar (micro balloons) work well too. Would believe any hyposcopic soft filler would work well. Friend used baby powder thickened dope on his 1/4 PT17. Renamed BP17 for that nitro gas baby powder aroma. 😀
FYI: Iron Oxide (doped) and aluminum dope on linen brought the Hindenburg down. Effectively makes a weak thermite composite.
Just butting in here -
Since no one has mentioned it, there are specialty finishing resins meant for putting a smooth top coat on top of fiberglass and epoxy. Z-poxy is one that I have used. They sand easily and are designed for this purpose.
Aircraft Dope is currently 'difficult' to source. Certainly so for hobby uses.
Don't believe? try it 🙂
Perhaps an aircraft resto business?
Time was that fingernail paints were 'dope' ...may still be.. But the prices they charge the vain are horrific.
Epoxies are every bit as dangerous., likely even more so.. but the legislative wizards haven't caught up .. yet.
