Shigaclone MKII Black - The builders Thread
Good to see you back Erik 🙂
Tibi any suggestions on a higher quality cap for the laser mod? I can't stop grinning at that vishay every time I put a CD on my player 🙂
BTW I just received the russian mica capacitors. I will try them on C11 eventually, but currently I am trying some other stuff too, so I will have to wait to give them a fair chance against the already very nice Cornel Dubillier.
So far I have tested:
Arcotronics PET - very good bass extension, very musical
Wima PET - good bass, but not as Arco
CD silver-mica 1nF - the best so far
0.1uF tantalum - good resolution but dry
Tibi
Tibi
So 1nF works too? that s good news. I got some russians, but no way they are fitting in there... I think I have a CD too, but no idea where it is... Plus it is too thick for the sanyo mecha... It will touch the plastic frame when the sled is in the end of the disc. Unless I scrape some material
I was wondering.....
Tibi did you try to leave a replacement cap out alltogether
So only remove the original and listen without ......?
I already did this and sound degradation is very audible. Beside this, unit lost track on my low beta scratched CD test.
Without cap entire optical unit may be affected by RF noise.
Today I have tested Vishay MKP 1837. I like it a lot. Same deepness like Arco and resolution very close to CD silver-mica. So far the best match.
Tibi
