Hi Andrej,
A package arrived with two nice red boxes in it.
The build can start 🙂
Thanks for this project !
Danny
Danny
Realy top notch quality
Hi Andrej,
Your boxes arrived today.
The nice packaging gave me the feeling I got some big power triodes.
No schematic inside but I understand the reason.
Francis
Francis
Haha, I didn't wanted to be impatient, but I had to restrain myself to ask the same question....
So....how was your weekend with the FO?
... Maybe he is waiting the SMPS3k to come 🙂 🙂
In that case I am even more curious......
Great pictures LC, lot of fuel and horsepower in middle of box to get speaker coils on job.........
This much of power has a lot of juice, so far all the coils says
Hi LC,
Are you going to replace those Samwha caps from your SMPS1200A400? If you saw a big jump in SQ with Connex PSUs using different caps, I'm pretty sure you'd have the same effects here?
Do
Of course there's still some room for an improvement, better caps are preferred always. Mundorfs on First One modules are there for a reason - to compensate such anomalies in a great portion.
Yes, one single reference GND/Earth chassis point is mandatory. No direct GND connection from First One PCB to the heatsink is present, no GND loops possible. Still First One has a clever solution implemented so it is completely safe to experiment with powered First One bolted to the heatsink and still outside the chassis. It won't oscillate or be unstable in any way.Hi, LC, qestion about 0V (zero volt) and GND/Chassis and earth.
Do you still recomend to have the 0V of the 2 SMPS linked to the chassis in a single point (seems there are 3 black wires on a screw close to the AC outlet on the picture) ?
Did you design the FO PCB to force a 0V connection by the screws of the tranis to the heatsink , like in VSSA ? (seems not on the picture 🙂 )
and finally, why not having a loop breaking circuit with diodes+R+C like described in ESP Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
thanks
So,how about Your listening Impressions on the Weekend, LC.
Please read my next post about SMPS and grounding.
Oh, what a bad idea with SMPS ;-)why not having a loop breaking circuit with diodes+R+C like described in ESP Earthing (Grounding) Your Hi-Fi - Tricks and Techniques
SMPS recommendation - final
Hi GB members
Little bit late on presenting the answer to the people invested in the First One, but with a good reason not to hurry too much on such crucial and important information about powering the amplifier.
Well, one single planned listening session unintentionally extended and prolonged from the weekend way till today as we got some firm conclusions, unanimous consensus among all present.
Two First One amplifiers, one with single SMPS1200A400, the other with dual SMPS1200A400, present. The source was Naim SuperUniti, speakers Thiel CS2.4, cabling multi UTP twisted pairs.
As usual both amps were preheated, each runing on music programme for a good hour before we compared them on five test tracks, volume leveled for each track on both sessions.
The result is not so far from our expectations, tight similarity with very slight differences noticable on momentary A-B test, otherwise, on not so closely conducted comparisons, it would be very hard or even impossible to recognize among them.
In which cases to choose single or double SMPS solution greatly depends on speaker's efficiency and impedance, these two parameters dictating how power hungry your speakers are and of course how loud you want them to be.
The ultimate and preferred First One solution is still dual mono configuration, although single SMPS completely fulfills the needs in a smaller system.
Great care has to be paid to properly conducted wiring, especially grounding as proposed in the manual. Slightly changed and optimized in chassis GND sch will be published together with DC sense circuit here soon.
Regards L.C.
Hi GB members
Regards L.C.
Hi LC,You think there gona be a Spezial Price for SMPS from Hypex or who to Contact direct?
Will be great!!
Hi guys
As already explained I won't lead GB for any SMPS since there are so many producers, wishes present, also logistics around organizing resale. My decision is only to recommend the most suitable SMPS for the First One and at the same time disclaim any rumour about promoting specific one for getting provision from a certain producer. My aim here is just to let you know how to squeeze most juice from the First One module and doing that on a safe side.
Regards L.C. 😉
Regards L.C. 😉
I understand what You mean.I think that a lot of Persons might follw Your advice though and want to buy that SMPS1200/400.That`s why I ask if there might be a spezial Price for DIYA Members,if we ask the right Person and i thought You already had someone to talk to.
Hi you can contact Mr. Niels Burema at Hypex and explain about the GB taking place here, maybe he can help with the price if there will be enough interest.I understand what You mean.I think that a lot of Persons might follw Your advice though and want to buy that SMPS1200/400.That`s why I ask if there might be a spezial Price for DIYA Members,if we ask the right Person and i thought You already had someone to talk to.
This is the Answer from Hypex.
Hello sir,
The price you see on the webshop for the SMPS1200A400 is as low as we can get
for DIY. €150,- is already cheaper then the special SMPS600 we sell for the
NC400 modules and the SMPS1200 is twice the power of the SMPS600.
Kind regards,
Niels Burema
Sales
Hypex Electronics BV
Hello sir,
Kind regards,
Niels Burema
Sales
Hello sir,
Kind regards,
Niels Burema
Sales
the truth is a year ago it was about 220(can,t remember exactly)
Hi, can you direct me to some link where temp coeficient of this heatsink is noticeable?I've two heatsinks of 20cm x 8 cm each.So one module per sink are those big enough?
First One has 280 mA idle current (sum current per rail) so at +/-63 V module is dissipating 35,28 W idle power and that is quite a lot because it is constant, filling heatsink thermal capacity substantially, something not to underestimate at all.
Hi LC, two red beauties are here, Thanks
One question:
What about single SMPS3k instead of dual SMPS1200, sound wise ?
One question:
- Vendor's Bazaar
- First One - mosFET amplifier module
