The David N.J.White 100W MOSFET amplifier
Hi Katie,
Try to swap the transformer or the PSU...
maybe it is over voltage...
I've try similar with BJT output & a little different PSU brings different bias, different stability too
Then measured again, check if the voltage is similar with the normal one
John
while you're in there measure the voltages at the base of tr1 (or across R10) and tr3 (or across R12) as well.
fwiw it were my amp i'd just snip the leads of TR4 and TR5 near the 90 degree bends i/o desoldering them off the pcb. Easy job to resolder them after. This also makes it easy to check that TR4,TR5 and TR2 are properly insulated from the heatsink. But your decision.
Too late Kasey.
I've removed TR2, 4 & 5 and they all seem OK.
I've posted the results on the schematic.
You can't have a 6 volt differential across a B-E junction (TR5) unless it is reverse biased. Your readings show its "not" (emitter positive with respect to base) which leaves the possibility that TR5 isn't a PNP, or that its faulty or fitted incorrectly.
agree but it apparently tested out above ok ?
Not possible 🙂
Its the same as saying "I have 6 volts across a forward biased silicon diode"... but it checks OK. There is one more possibility, but I would doubt this, and that is that the whole area around the transistor is oscillating at RF which would make all DC readings invalid. One quick check with a scope would prove/disprove that though... as would a well placed finger around that area.
Here is the equivalent circuit of the junctions. For you to have 0 volts on the emitter and -6 on the base means that the B-E junction (which can be represented as a diode) is dropping 6 volts while supposedly forward biased. That is not possible.
are you sure they are installed the same way on both channels. Look at the middle transistor in each of these images carefully.
edit: also shouldn't there be an insulator?
Tony.
0.9 volts assuming its accurate is too high. Without being familiar with your meter I wouldn't like to say how that should be interpreted. The raw numbers say something is not right.
Work to what you can see is definitely wrong, which is the 6 volts we had above.
