E-MU 0404 USB 2.0 and some "artifacts peaks" on left channel
Fixed it....
Just bought two units on Kijiji and modded them. Worked great. Thanks sidiy and everyone else who contributed.
In order:
Left 1 Before Left 1 After left 2 Before Left 2 After
Thanks again
Matt
Is there any news about development of this card?
I am thinking some multiturn pots for inputs and output for precise handling and opamps like LME49720.
Member "1audio" changed the opamps with LME49720 at the EMU 1212m with 10dB THD improvement.
From what I know, no!
At the following link NwAvGuy: Op Amp Measurements
there is a test to various opamps (the test done for O2 Headphone Amp).
At least to Noise Floor, the JRC2068 internal opamps of emu have very low noise equal to OPA227/2227.
The Author says at gains less to 4X, nothing overall could be the NJM2068 (same to JRC2068).
I don't know about THD level !
He didn't measured AD8599 nor LME49720 though.
AD8599 have better noise per datasheet, and both AD8599 and LME49720 have much better THD+N: 110-120dB vs. 100dB. Not shure if ADC itself will not mask it. It's 15 minutes for me to change four opamps on the left channel, so it's not a big deal. I need it for measurement purposes, so I don't bother for musiality.
The EMU 0404 (and all the other USB thingies with numbers from EMU) use the AK5385 level ADC. Its quite good but has a rising noise floor starting at about 30 KHz. The only fix is a better ADC. Unfortunately the only better option is the AK5394A which is about twice the footprint so its not a drop in at all.
Some really enterprising soul could figure out an airplane board with the better ADC and associated stuff but what a task.
Upgrading the opamps to LME49720's etc. will lower the distortion some.
I do wish these boxes were easier to open and work with.
