AudioPower DPS-500-DA in GB
Hi Roberto
Thanks for the offer and keeping up with us.
If the DPS-500/S-64V have the same audio characteristics and are reliable then of course I confirm!
I'm trusting on audio-power's quality testing before the units are send of to the customers 😉.
Does the DPS-500/S-64V + frame have the same dimensions as the DA version? (drop in replacement)
Kind regards
Hi Guys,
To clarify, after various versions and accessories changed along the thread.
I show you the "Red Power-Unit," Already we know the special green (as coming, on AudioPower new products)
As default, it is green, but I can change in this version for diy, with some balck or red if you want.
As visible on pcb, the DPS-500-xx uses same PCB.
the "S" version, uses the special trafo (and others components) as described in the datasheet of the "S" version "and some components, both within the Power-Unit.
Therefore, the performances are identical, only changes the power. (output and dissipation)
In simple words, this is the "S" version dedicated to amateurs, with Nichicon set output caps, changed. (as "DA" version). no other.
The difference is remarkable, considering that the "S" version, can push safely, 1 ch class AB amp, with 4 mosfets per side.
The prices same as "DA" for reason I have already explained, this means that I can not hold long this GB open at this price.
I think that is obvious. then the GB closed 10/05/2014.
The product is guaranteed for two years (full parts). AudioPower is informed of this gb. the products includes the S/N and date.
two words, for some pm I received.
Each company has its own philosophy . we play in "prestige" ...we try 🙂
then , all products are fitted with the same components , both active to passive ( resistors included) , this means a complete different management and investment.
then , closed the project with high voltage Rubycon caps for example , That means to have all Rubycon 105 ° , same lot of production . applied , to all others components.
Prices: one DPS-500/S 135€+8€ frame.
Spedition: only by ups 25-30€ depeand country.
Right 2 photos, hi-res is visible in others photos I think.
Hi Roberto
Kind regards
thanks for your confirmation. 🙂
yes, same as plug and play.
And...Green 🙂
Mini Productions for Diy started today ...😛
Qty received from Nichicon, better of samples received before... full audio grade at output we have then.
well, I think new weekend, I can show all qty ready. :up:
Updated the GB list with the new version.
danny_66 2x DPS-500/S-64V / with frame
pinnocchio 2x DPS-500/S-64V with frame
Eric06 2x DPS-500/S-64V / with frame
Catal 2x DPS-500/S-64V / with frame
Jokari69 2x DPS-500/S-64V / with frame
maxidcx 2x DPS-500/S-64V / with frame
Edionysus 2x DPS-500/S-64V / with frame
The NGR32 (special trafo on DPS-500/S)
Hi guys ,
I can show good recording data, 3ch (temperature of transformer , heatsink , and output current on load) for two hours of acquisition. but I thought well, to show the special transformer , which is used in the "S" version of the DPS -500.
This also, allows people with little knowledge in the field of ferrites, or with zero knowledge , to look at a table for ferrites "EE" , to see if this is greater than EE65 , in a simple way , considering that the first parameter to choose the power of a transformer , it is just the volume of the ferrite .
I can not show the two pages of the parameters of this transformer .
In 2007, I designed this new transformer , need for special uses in other sectors, whereas we got 2Kw , with 28mm of height and space, as you can see. or , depending how it is used , it allows incredible power of up to 4kW each, in series parallel configuration also . or ultra-low temperatures ( around 4 ° C of delta) for other special compact applications,etc,etc.
I know well that the members in the list , have no doubts about what I have presented so far about the DPS -500 , Measures included.
I plan to refer to false and stupid technical gentlemen. who spends his life , in copy, instead of studying.
Permeability,dimensions ratio and materials, absolutely exclusive , as the property of MDI laboratory .
The good quantity of dps-500/S,will be ready in 3-4 days , I will put the photos .
Updated the GB list.
The DPS-500/S are in the Nichicon assembly tomorrow, then go on the final test.
Please, considering the small quantity, it is proper to know if you all confirmed via pm. absolute np, just I know.
P.S. The transformer in the picture, is shown without final machining, just to see the size of the central trunk.
regards
I'm in.
CaféNoir 2x DPS-500/S-64V / with frame
Cristi 1x DPS-500/S-64V / no frame
The gb close today.
Today later, I show the photo of all products as promise.
INFO
I have under test, A unreg version as Dps-500/S. 22Amp Output witn active power ripple filter. later I show just for curiosity. 🙂
Catal 2x DPS-500/S-64V / with frame - 2x DPS-500/DA-45v
Catal 2x DPS-500/S-64V / with frame - 2x DPS-500/DA-45v (Heatsink included as default)
Thanks,
Good choice, for which amps you want to use? VSSA?
CafèNoir:
I know you have 2xDPS-500/DA.
how did you use?
Well,
I'm sure you love the sound by the DPS-500/DA.
Also, the ratio from Vcc rail to power Audio output. offer by 500 series, is the absolute highest ever achieved (in continuos SIN from 60Hz to 20Khz).
Just to clarify, with all the chaos that surrounds these smps for Audio. 😛
N.B. This is the latest version, entered in the shop AudioPower
GB Closed.
For payment use PayPal, "sales@audiopower.it"
add on note: GB-DPS-500/S+AL frame complete.
For DA version: GB-DPS-500/DA 44-46V complete of Heatsink.
Some who want to use bank transfer, I am sending data via pm.
AudioPower Info:
will be deleted from the shop (in anticipation of new products)
So, will remain only this smps for Audio:
DPS-500 / S (includes full customization)
DPS-500/DA 44-46V (this new release)
DPS-400/S1 (use a new transformer)
DPS-400/S2 (special transformer as DPS-500 / S)
DPS-400/IPA and DPS-400/LV (both new releases)
short put the diagram for proper connection of the DPS-500 and some simple circuits to be mounted on a pre-drilled board,*
for the optically isolated input "Fast Break".
Remote control on / off.
Remote control via trig.input 12V.
DC Offset protection.
P.S.
I await payments, to proceed with the installation of the Power-Unit (right voltage will be chosen)
New DPS-500/UR
Hi to all,
We announce with pleasure, a new version of our DPS-500-xx series, oriented to the increasing demand of smps for Audio for professional use.
This version uses the fast stage regulator, already used on our dps-500S but with a new concept of differential regulation.
In a nutshell, you can fix a output voltage, eg 62V, this is absolutely fixed voltage (Vs the AC line changes) later, the control circuit operates with a differentiated calculation of, the required current, and voltage set internally, as ref. the regulator acts within this range.
So we have:
little heat dissipated.
Output voltage completely clean, with zero spike and only 50mV @ 8A (resistive load) HF (150Kz).
Compact size
high reliability
An SMPS designed for audio amplifiers with certified performance, suitable for high power Class AB amplifiers. (1 or 2 amps, with a total peak power of 1kW)
For more info, please contact me at info@audiopower.it
The launch price is 158 € + VAT (excluding AL Frame)
Special offer of a couple at € 280 for private audiophiles
Nice day to all
New DPS-500/UR
So we have:
Output voltage completely clean, with zero spike and only 50mV @ 8A (resistive load) of HF (150Kz).
Compact size
high reliability
An SMPS designed for audio amplifiers with certified performance, suitable for high power Class AB amplifiers. (for 1 or 2 amps, with a total peak power of 1kW)
Nice day to all
Stefania Enea
