HA!...HA!...HA!....
~ 20 V/uS compared to 0.5 V/uS
Puts it within Jungs criteria for audio use .....
HA!...HA!...HA!....
Yes, Hitsware, but look at the 'small print'. It is vastly better than the 741 in rise-time and slew-rate, but disappointing in actual performance BELOW SLEW RATE. This is WHY Otala did not like to use slew rate as the dominant criterion. (I don't necessarily agree with him on this)
I got the impression from some of the comments that the 'S' was considered
meaningless .... Far from it no matter the small print .....
Slew enhanced op-amps are an obscure backwater of basicly useless technology, we learned that soon after they were proposed.
Now, David L has actually asked a valuable question as to how we can get the same 'results' from modern test equipment as we got with the relatively 'old fashioned' AD524 IN-AMP with 'modern' test equipment? Personally, I don't yet know, because of the limitations of the 'modern' test equipment as I find it. Perhaps an analog differential subtraction test would be useful to get an error signal, that then could be further processed. In any case, DA is real, and it can generate real problems with certain common audio signals. Ignore it at your own risk.
That cap test is interesting, I think I could actually do that with my old Tek 561B with it's 10uV/1MHz differential amp and my SG504. I don't think resistor nonlinearity could be a problem, could it?
The MC7xxx regulators by OnSemi (I believe MC parts were from Motorola formerly?) are actually better than the LM-based parts based on the datasheets, maybe they improved it? That was an unrelated thought when I saw the MC parts earlier.
On caps, have they developed a way to make thinner MKT films? I complained at Digikey for having a 3.3uF Epcos cap for 5mm pin spacing, very cheap, and they corrected it by using a newer datasheet. WIMA even has 10uF MKT's with 5mm spacing and I got a few of those. The specific cap was the B32529 from Epcos - it seems to be the cheapest uF range MKT for 5mm pin spacing. The only reason I didn't get a bunch was because the DF specs seemed to show unusually high ESR.
Concerning "special" capacitors, I'm surprised no one has brought up the Kemet R73, film/foil MKP. Also the Kemet PFR (although just very small capacitors). Formerly Evox-Rifa, which Kemet aquired. There seems to be a conspicuous stigma towards Kemet.
Actually I was asking you when you were going to stop driving down memory lane and post something new instead but frankly I give up. Have fun living in the past, this thread is useless.
