DAC-END R (ES9018) full assembled board
I open GR for PCB LL1684 in this :
Interest list for LL1684 PCB SET (2 channels):
1. NicMac, 1 set (possibly also the transformers)
2. palmito, 1 set
3. Misterwolf, 1 set
4. rredline, 1 set
5. audiodesign, 1 set
In about 15 days to complete PCB!
Thanks for your interest!
http://www.diyaudio.com/forums/quanghao-audio-design/246579-super-v-i-converted-ll1684.html
thank all!
quanghao
2. palmito, 1 set
4. rredline, 1 set
6. Claudio M. 1 set
After receiving the final version of DAC modules we have detected a very little oscillations on shunt regulators in high frequency range (about 150KHz).
Measurements and simulations made with the collaboration of CAAD allowed to find a simple solution to this problem.
To make this modifications are not necessarily required SMD components but if you want to use SMD and you have problems to find these components you can ask to Quang Hào.
1) Remove R9 on op-amp modules (as suggested before)
2) Remove R10 on op-amp modules (as suggested before)
The following modification must only be made only on +1.2V , +3,3V and +15V shunt regulators.
3) Add 100n X7R as described on attached pic -->All are X7R (better dialectric compared to U5r , Z5R etc)
4) Add 1uF X7R as described on attached pic -->All are X7R (better dialectric compared to U5r , Z5R etc)
These modifications also will reduce the temperature on the shunt of the op-amp module.
The modification as been applied on the last DAC modules sent.
See the image created by CAAD.
Hi Andrea,
Will you know the mouser/digikey part# for those caps(X7R) ? I am ordering the LMV7219 so will like to get the caps also.
Thanks,
Gjorgji
The spdif issue
Hello All,
I recieve my dac few days ago
starting to lisntenig it...
but some "glitch" and LOCK problems :
I have 2 cables : 1 metter standard grade
5 m hq grade
- with the 1m random glitch/lock desepear (depends use of computer, even plug/unplug soldering iron)
- wtih the 5m same "glitch" and lost of signal for 1s (the 2 leds light off for 1/2s)
I look the posts ;
So , I had put the 100nf cap
=> its solved my "lost of signal" => it's work like the 1m
I have always the glitch/lock, more frequent at >44khz
So I need to change the LMV7219 ??! :faint:
Thanks for advice
julien
Hi!
you dac not need mode all, I was fix all!
220V voltage need to be connected to the earth, see photos
thanks
I use this PIC programmer to upgrade the firmware, cheaper than Pick-It.
Search in eBay or Aliexpress for "K150 PICPRO", it costs about $12.67.
It is made by BAITE and uses FTDI USB-Serial chip.
A side note, on my system, after the programming status bar reach 100%, somehow it pauses for about 8 minutes before the "Successful" prompt appeared, it works though, so be patience if this occurred.
I have uploaded the driver, programming software and a simple tutorial here:
BAITE K150 PICPRO Programmer Drv & SW.zip
Thank you for the tip and the tutorial, it was very useful.
LL1684 PCB and DAC v2
I had the LL1684 and the PCB, the address you sent me, so I send them to you!
Please see image
Our warmest thanks
I had the LL11684 and the PCB, the address you sent me, so I send them to you!
Please see image
Our warmest thanks
