Article - Sony VFETs part 1
Thank you guys. The photography is bad. Really capacitor is not so close to heatsink. Transformer is very big, 500VA, (I had it from a failed project). One for channel. Really, all except VFET are from failed projects. I did the first version of Nelson and I had not any problem with noise, but I used laboratory power supply (3 units) and I used KD for K82 and KF for J28. Now I do not know..
VFET protection
Hi Nelson,
If you don't mind couple questions (reposting from before as they got 'lost'):
- What is the overall gain/sensitivity of this amp?
- Does it need any speaker protection from DC?
- Do Version1 output SITs need to be insulated from the heatsink (since their drains are connected)?
- Can output SITs be of different grade (e.g. KD-33 and KE-33) or the same grade is required?
Thanks,
Vlad
You could of course implement the diyaudio store's DC protection circuit board
Possibly you can find something at Rod Elliot's site.
Nelson Pass uses a regulated power supply for the CSX-amplifiers. It should be fairy easy to sense the current and turn off the power supply/the amplifier in case of excessive currents.
I'm curious where you are placing your Jensen input trafo, so it is not influenced by the big toroid.....
Jensen transformers GB
Hi all Diyers
Today we have potentially all in GB 50 pieces of Jensen transformer.
Lower price possible :2c:! That is very cool to play team game 😀
Next step is finalise this list and buy them in USA and distribute to your sweet home around the world.
********** Let's talk together about in this thread ! **********
http://www.diyaudio.com/forums/grou...-jensen-transformers-sony-vfet-project-6.html
Greetings
🙄:wrench:
