OS can you post spooky's LT spice file? When pcb layout files will be availiable for spooky 1.2 and nad 1.3 ? will they be the final versions?? I am a bit late with my progress because i have run out of parts for cfa-x ips and i am waiting for final versions of nad and spooky to be ready to order all the parts...
It is ready for the "embarrassment phase" .... show me my errors.
(below 1/2).
Updated the board , the schema , and a BOM.
-"X" will also allow to run the servo inverting (like the 1.2) .... cut the
thin trace above C10 , R27 to "X" , jumper the other X's. Default is
non-inverting fed to current FB.
-labeled "ccs pos/neg adj." , (R5/10)these could be jumpered and omitted ...
(R6/9) - can be a cheap 680R ... if you can't afford 2-2us$ trimmers. 😱
Servo actually makes the trimmers redundant , but you might want to
"tweak" the VAS current with them (or balance a "sloppy" input pair).
-input cap is 3.5mm wima / 5/7.5/or 10mm LS.
-Seen thimios's v1.2 - every spacing and layout consideration has
been "anally" addressed. 😀
Gonad 😎😎 is by far the best "simplicity to performance" amp I've
run across. Only the "spook" can beat it (not by much).
OS
Marketing tag-line: "Have you got a pair?"
Hm, if I use a pair of the NAD input stages and a pair of the five pair output stages together can I safely say I have a pair of Monster GoNADs? Must be a manly man thing... Or me just being silly 😀.
I have no problem with the name between friends but the ladies might not appreciate it!
Spent two hours in a job interview today I hate those things.
That is ...😎😎😎
What would you do with 5 pair ? 😱
I have no harem ??
All the hardcore tech needs a humorous outlet ... 🙂
This was "calling" for a joke !
But, when you listen to the "party music" on this setup , you better
have at least 1 pair ...
OS
Ahhh , the spooky ....
I avoided this topology for the longest time.
It is hard to layout , uses more parts .... but some really like it.
As a simulation , it exceeds the "blameless" .... it exceeds ALL !!
(especially at 200V p-p)
Tomorrow , I think all is perfect ....
You will be able to print out my masterpieces.
I'll even include BOM's !
OS
Not to offend the "gnomes" ... 😀
Here it is ... print away - very "pretty" layout !
OS
hello uncle Os, schematic Q1-Q2 (use sa1360/3423 t0-126 case) meanwhile on the layout use t0-92?
Those were just swapped to see the "slop factor" of the circuit.
Simulated with anything (992/1845 - mpsa - 1015/1815)
The BOM will be more specific.
PS - you actually could use those 126's - it would still work !!
OS
OS
Modest we are not! 😀
OS
When you have a moment, and if so inclined, could you zip and post the Sprint LAY file? Pretty please?
Do I hear Gerber in the future?
A busy Weekend?Not to offend the "gnomes" ... 😀
OS
If i find any photoresist pcb.....
That's the plan. I'd like to basically do the same as I did for the OPS and take advantage of the two sided process to eliminate jumpers for any boards done at a board house. Same goes for Spooky. Those are the two that have piqued my interest the most.
Right on, right on!
I'm with you! I would prefer a double sided PCB over single sided with jumpers.
In my case I was also toying with the idea of trading the Euro connectors for right angle headers and sockets. Those bugger are cheap, pretty stout and would have no problem with the current and voltages involved. You end up with a package that easily slips into a chassis. I'd further modify the IPS boards to accept both a rca phono (unbalanced) and XLR (balanced) inputs directly attached to the PCB without the intervening wire and connector.
If necessary you could always add a right angle bracket by Keystone (or others) to further stiffen the package.
OS can you explain these "x" symbols on pcb please?
Thimios.
Thimios.
Middle road ...
Some have lower PPM under ideal conditions. At 14 devices , it will
beat the pant's off of anything (short of below).
Syn08's PGP - PGP
is the PPM "winner" ... at the cost of 32+ devices, it has .5ppm.
14 devices with 5ppm is a better project. 32 is scary to most hobbyists. 🙁
I think when this excellent engineer was a member - only a couple builds
were attempted. For every PGP , 200 "DX" amps were built ! 😱
(below) is the "middle road" ... with the below layout and good matching ,
it can be built cheaply , error free , and is easy to support.
"Cheap PPM" ! 😀
OS
Syn08's PGP - PGP
"Cheap PPM" ! 😀
OS
Thimios.
replace the very top jumper with 220k , bridge the X's , omit R28 ,extend R27 to "x"
and it will be V1.2 (like yours). Servo will be inverting and trimming the
diamond instead of the CF node (non-inv.)
Nice to have choices ...
Carl - there's your "leach" ... 😎
Edit - also thin trace above C10 (cut).
OS
Syn08's PGP - PGP
"Cheap PPM" ! 😀
OS
- Slewmaster - CFA vs. VFA "Rumble"
