Babbelfish J PCBs
You mean images?
(The pot is not connected)
What would you think is the minimum supply capacitance? Maybe these caps are old...
Supply ripple is 0.5 V
I just start the artwork for the pcb on the Babelfish J with input SJ109BL (because I have some).
I also have a lot of 0.47 Ohm/5W resistors. Would there be an easy way to calculate the needed R- value with a given voltage and Iq and so the output wattage or other way around?
Or in other words: I like to use these resitors and my max. power should be 25-30 W, so which voltage and Iq I have choose?
