Slewmaster - CFA vs. VFA "Rumble"
Analogy....
Triac soft start to the mains power transformer has been used on Pro Amps for years, & is very successful 😉 Another way it's been done, is a with a circa 50W 0.5R resistor in series with the Tranny, which gets shorted out with a power relay after a delay.
That upc1237 looks the ticket though 🙂
Bonsai's solid state output protection "appears" to be very well worth exploring.
Also a mosfet, or bipolar, DC supply cutoff seems like a good idea too !
Seems to me ....
Disconnecting the rails is like "pulling the plug" (on the whole amp)
in a microsecond. Minus the main caps , of course.
Disconnecting the speakers is like "cutting the cord" (while the room
fills with magic smoke).
Both are valid techniques , I need to "dream on it" ... 😀
OS
First test .
Amplifier is singing!
+/-44V
idle current =20mA
Offset= -1mV
One pair c5200 a 1943
Resistors R9,R11 changed from 5k6 to 3k3 because with 5k6 Vzener =5.3v only.
First test .
+/-44V
idle current =20mA
Offset= -1mV
This was predicted ... (zener "tweaking")
I will add this to the IPS schemas ..
3K3 for "baby" OPS 40-50V
4K7-5K6 for master - 60-70V
6k8 for 70-85V (monster).
This effect also reflects servo IC choice (2-4ma) , red LED current
and CCS current (all using the 12V supplies).
You do it just like I do ... start with 1 pair OP for 1st test 🙂 .
Smart !
OS
First measurements.1kHz,10KHz,20KHz,30KHz,40KHz.FULL POWER, PEAK TO PEAK 70V!
No:6 Nice symmetrical clip at 24V RMS
No:7 Hard clip.
1V RMS inp. 24V RMS out. just before clipping,72W RMS /8R/+-44V SUPPLY.
3 ways to reduce "overshoot" on your SW tests.
-39/43/47p C9.
-Inductor on the board ??
-fine tune the VAS Re/I
150Re - 1.2V =@ 7.5ma current.
This also might be the long wires or other
unknown/non-ideal conditions.
It's not bad at all - but could be a little better.
Clip behavior is supurb ... 🙂
OS
some people also use a capacitance of about 1uF in parallel with dummy load to view potential oscillation with difficult loads such as electrostatic speakers..you can use a small square wave input of about 10mv or 100mv at 10khz ancheck the response..
Another one ..
Some one..
found my "gla-survivor" thread ..
To do that endeavor justice .... the best "symasym" type IPS
I could muster is about to be unleashed.... drum roll ...
(below 2 ) is the schema ...
(below 1) is the output ...
(attached) is the .asc ... it is cool !
A mix of the Sansui /symasym /and the HK680 IPS ...
A cascoded/ differential /wilson current mirror "mutt"? of a VAS ..
Any "symasym" fans - it totally "smokes" the original ...
AND is kind of simple !!
OS
  • SYMASUI-CHI.asc
    SYMASUI-CHI.asc
-39/43/47p C9.
OS
My VAS seems to run in double current.
Please Ostripper have a look at measurments on the attached.
