Midbass horn
unaHm:
For experimental purposes hardboard will be ok.
For a permanent solution I used " wiggle board " also known as bendable plywood that come in 3/8" thickness ( only size I found ) and will easily bend to any horn profile. For my mid bass horn I used 4 layers per side with epoxy glue between each layer. Regular wood glue tends to shift and delaminate over time. the epoxy glue is much more rigid. I finished my horns by using oak veneer on the inside and oak wainscot on the exterior to give a finished look.
...what data would you need in order to make it appropriate for the Alpha 8?
I don't know about data, or how to use them 😛 ... but it would surely need more 'refinement'
here is another 'teaser' 😀
first is seen from above, and could be in a corner
second is turned around, and seen from the side
unaHm:
I agree on the glue front. The only time I use 'standard' wood glue is when I'm making instruments, which I'd imagine to be considerably stiffer than the thinner and more flexible horn walls.
Thanks for those tips, I'll bear that in mind!
For speaker building I'll usually use something like construction adhesive.
Thanks for the teaser, it looks nice! 🙂 Are you using a particular horn design, or are you just playing 'graphically' for now?
Based on that design, my goal would be to fit that 25" horn on the previous page into an 18x18" (45.72x45.72cm) footprint.
With the offset driver design, I noticed in HornResp that the response has quite a few resonant peaks. Would the same happen in that curved design?
you could achieve smaller footprint this way
actually, that last bit of 'sides' could be 'attached', and removed when not needed
how long was your original straight horn design ?
Would anybody like to comment on pattern flip? How bad is this? Just as bad as the "horrible" directivity issues a 7 inch woofer + 1 inch dome speaker suffers? or really, really bad? Our hearing is not that sensitive vertical.
We can certainly hear reflections from floor and ceiling, and those reflections being a longer path length than the direct path cause peaks and dips in the response.
Horns, if made large enough, can control the pattern so reflections from floor and ceiling can be minimized without resorting to acoustical treatment.
"Pattern flip" is simply a widening in the pattern at lower frequencies when the mouth is too small vertically to control the pattern.
As you can see below, the 90 x 45 degree horn starts to loose control below 4000 Hz (about the wavelength of the vertical horn dimension) so below that point more energy will be directed outside the nominal pattern, progressively increasing floor and ceiling reflections.
It is not a "horrible" transition, but if making or choosing a horn, unless vertical size (and the depth required for it) is a big concern, no reason to go for one that has compromised vertical control.
I know that this isn't to any particular scale, and the expansion probably isn't that great, but what about something like this?
Note - the right-hand side of the box is closed, and the horn now exits at the top of the picture.
I am amazed there is not a thread about folding horns @Diyaudio, with al the crazy examples together. I am a bit hesitant to empty out my complete "hornfold" directerory here. As recent convert to the "thou shall not fold a frontloaded horn" church. Wasn't the gist of the thread some page's ago, that only a Sato horn fold or a Western Electric 1 fold horn would not be detrimental to the midrange 🙂
