Thanks Brian. i completely missed that on the website. What about 3 sources? Can two OTTO-II's be used with a switch between them? I'm still not sure what the build will be exactly but am getting the options lined up before I start.
I got a little more clarification about what is wanted. I2s and AES as the two inputs. Can the OTTO-II do that? I looked and did not see anything that says it can't but would like to know for sure.
Will more OPUS DAC boards be available?
Boards should be here Monday. The LCDPS, Toslink, S/PDIF Transceiver and Metronome will be back in stock as well.
Opus is back in stock, along with Metronome, the S/PDIF Transceiver, Toslink module and LCDPS.
Would anybody know if it's possible to bypass the SRC in software mode?
(Hifiduinocode lists them,but not the "unused" one)
Kind of like PS Audio's NativeX,which totally bypasses the SRC and sounds better in this mode.
The datasheet should hold the answer...
Hi Russ/Brian
Just finished my Teleporter/Opus/Ventus/Volumite HA/PRE build and I have to say it sounds very good indeed. (Yes Brian I’m the Brit who never manages to order everything in one go😱)
I have the Opus Dc coupled to the Ventus and the pre out section is isolated when I plug headphones in.
The ventus really bring my HD650 to life with the stock gain setting.
I’m going to have a listen with it as a pre next which will be interesting when compared to my Buffalo 3/Legato (look ma no caps)
Thanks for a great sounding kit at a very reasonable price.🙂
Not a moan but a suggestion😀
I know that you must be busy but just a little snippet in the Manual about using the Opus in SW mode would be great.
I did find the answer on the support forum but was unsure if I had it right until the music flowed.
Just for others I have
I2S -0
And all the rest set to open(z)
Switch wise.
Thanks again
I2S -0
Switch wise.
Thanks again
Hi All
A quick update
Whilst I’ve enjoyed the Ventus as a headphone amp driving my hd650 I’ve felt that it was slightly less successful driving my Audiosector chip amp.
So I ordered an IVY3 and wow it sounds superb.😀
It just seems to do a better job which is no real surprise I guess because that’s what it was designed to do.
Great work Russ/Brian I’m very happy with the Teleporter/Opus/IVY3/Volumite IT SOUNDS Awesome.
So now the Ventus gets its own box and works as a standalone Headphone amp so it’s happy too.
Thanks again
A quick update
Thanks again
And the big surprise is how close it gets to my Teleporter/Buffalo3/Legato.
Outstanding VFM😀
Thanks angain
Outstanding VFM😀
Thanks angain
Outstanding VFM😀
Thanks angain
I agree, I have long maintained that the Opus is no slouch. I still listen to mine regularly.
Ummm...
"Native" and "Native X" modes on the PerfectWave DAC do not bypass the oversampling of the Wolfson Chip. These modes bypass the asynchronous sample rate converter, which is a TI chip. Even in "Native" and "Native X" modes, the oversampling and filtering of the Wolfson DAC chip are still active. Indeed, it would probably be a bad idea to run a delta sigma DAC like the Opus with no oversampling. If you use the Opus without a Metronome, via an i2S source, you are running it in the same way as "Native" mode in the PerfectWave DAC.
Would the Amanero or the Wavei/o be a better usb to IS2 for the opus dac since the twisted one is not avail right now?
Hi All
I've just started my opus project. My plan is to make my opus dac modul working with amanero usb and play dsd and pcm stream also without mechanical switching.
Amanero has i2c tools. Is there a way to do it ? So when my foobar sends DSD data to amanero I want it to change mode to dsd on dac with modifying register value.
Certainly I've come across with arduino solution written on hifiduino's site but a bit confusing to me. First I just want the automatic switching.
thanks in advance
Karoly
thanks in advance
Karoly
- More Vendors...
- Twisted Pear
- Mr White's "Opus", designing a simple balanced DAC
