Pictures of your diy Pass amplifier
Haha! No, I don't want an integrated amp 🙂 And yes, it's the softstart from Sjostrom. Nice stuff he has! The PSU is also Sjostrom. It was handy so I use the softstart module as low power switch module for the nice on/off button. It also drives the blue LED in the switch. A bit overkill, I know. But no extra cost 🙂 And since I have the same module in my Class A amp, the LED strength is exactly the same 🙂 Witch is nice.
Smallest board
Remember to make the cables from the regulator board to the B1 as short as possible for best performance. Inductance of long cabling its no good at all for regulation.
What is the purpose of the smallest board placed between the softstart and the switch?
Hi regiregi22,
The power cable from the PSU to the B1 is only 8cm long.
That small pcb is just a tiny power supply for the input switch unit. It needs 12 to 15VDC and the big PSU is 22 VDC. So I needed a small one(Velleman) to reduce power from 22VDC to 15VDC.
The B1 will operate without a regulated supply.
It does not need a regulated supply.
It does need a low mains ripple supply.
Unregulated can give a low ripple supply.
That is what the standard B1 shows. An enormous filter capacitor for a tiny quiescent current.
My Aleph 30
