CFA Topology Audio Amplifiers
Well, to make matters worse somewhat --- as I recall, when I put together the topology often shown and used here (not the same as an IC CFA topology -Elantec etal) I found, experimentally, that it would behave a little differently if the circuit Z values were high and if they were low. When low, the classical CFA characteristic started to show more... current control. [same supply voltages]
I used low circuit Z values for several reasons.... one for low noise and also so that parasitic and stray C would have little effect until very high freq. No values higher than 1K Ohm were used.
Thx-RNMarsh
What commercially available amps are cfa ................?
There is many commercialy CFA amps, all new Marantzs are based on old Pioneer A400 circuit
You the "man". 😀
A400 is diamond buffered input , Wilson VAS , AND compound Vbe EF3.
My design came to these same "conclusions" without knowledge
of the old pioneer.
Have you seen or heard this amp ??
ps - also notice the a400 is low gain in the power amp - they use an op-amp
for the rest of the gain , like SYN08's "VSOP" .
OS
Low pass filter in the feedback loop due to the RC (C being parasitic capacitance at the emitter) ?
This imply we have to compensate the VAS more, so, reduced slew-rate/current on demand...bandwidths etc.
We can do the same with CF OPAs, it is obvious the OPA don't change its nature 🙂
wilson's controversial amp...
amp asc. files are below.
Just for fun , remove all compensation (C5/6). She still runs. 😀
Remove a current source , CF keeps offset below 5 V .. speakers
would not burn. A Very" idiotproof" design , as well.
By swapping models , "critical" matching would not be an issue.
As easy (or easier) than most of my VFA designs.
Off to the "cave" to layout in sprint ..... 😎
I'm going to make this one look "eerie"/controversial (UV led CCS's) ....
OS
OS
Beter use ksa992/ksc1845 instead mpsa42/92 in place Q5,Q6,Q8 and Q9.
Thanks Pavel ......
Accuphase is high end amp but not the only ones, Myryad comes to mind, they have been using CFA since late 80s. One of the 2 Sony high end amps is a CFA. Pioneer first used this topology in 1978 (MZ1) in the top of the range amps, they have a couple of US patents on it. They were also the pioneers of the CFA topology using JFets as inputs and hold patents with regard to these. They have too many CFAs to mention all here.
The complete ranges of NAD amplifiers except for some AV recievers are since about 2003 all CFA designs.
Renkus Hein which is PA manufacturer uses CFA.
I can carry on with the list but it will get very long.
The operation going from low current/high Z circuit to high current/low z circuit values/operation with same topology caused the circuit to behave more like CFA in regards to peaking/gain/distortion (both lightly loaded output - this was a line level amp) etc. Might be able to SIM and see now?
But I am going by memory from 35 years ago.... might be something else.
Thx-RNMarsh
