Reading the tda1541 datasheet last night I finally clicked I think on what the simutaneous mode is. From what I understand the chip can be fed by offset binary or twos complement dependant on the voltage applied to one of the pins, either -5v,0v or +5v. Simutaneous mode is -5v?
And Ians board separates these and then DL and DR go to their independant input pins?
Is that correct? Is that the mode you are using
Note here, the datasheet talks about input modes, Pin 27 needs to be at -5V or VDD1 potential to allow simultaneous mode. It also shows the DL, DR, BCK and LE pin connections.
Hope this helps and you get it running! Report back your thoughts!
Drew.
Drew.
Drew.
cheers Drew,
many thanks for your hint! I think I simply missed pin27 Will check once come home.
352.8 KHz music was playing on both NOS TDA1541A and PCM1704 without any problem. With higher Fs, they sound more analog. I have to say, TDA1541A sounds wonderful. I never thought it can sound like this way, with much higher Fs, it sounds very impressed.
Unfortunately I can’t find any working software based real time up-sampling apps which can go up to 384 KHz so far for both Mac and PC, any recommendation?
IanIan
Look into Signalyst.. He's got oversampling algorithm's that rival the best. And he is continually updating support and upgrades, recently went to 80bit precision for minimal resolution loss digital volume control and upsampling! If he had HDCD decoding for the M$ version it would be perfect. This is the future, and made possible by your project, thanks again.
And for Mac users, I give the highest recommendation to Audirvana Plus. It uses the excellent iZotope SRC engine and allows for full customization of all digital filter parameters. It will recognize USB DAC up to 768KHz, and also supports DSD in several modes (native, DoP, DSD>PCM). Wonderful sound and easy to use!
cheers Ian,
got the new pcm board! many thanks, it looks splendid!
It seems that I need some advice or help with connecting it with Amanero and TDA1541 dac from Oliver.
Need to say that Amanero + TDA alone work fine.
the PCM board and TDA are connected as stated in the manual, jumper is set to JOB.
Amanero and PCM are connected in the following way:
MCLK -> MCLK
BCLK -> SCK
FSCLK -> WS
Data -> Data
Ground -> Ground
all three leds are glowing, so connection should be correct I assume.
DL and DR output pins are soldered directly to TDA chip.
BCK also goes directly to TDA chip.
LLLR is connected through 1N4148 diode as stated for -ecdesigns- latest 3.3.v i2s modification.
Unfortunately on the output of my DAC I get huge distortions, what could it be? Tried to set the board at half speed, no difference.
Did you switch TDA1541A to simultaneous mode by jumping pin 27 to -5V?
PCM interface is different from I2S interface.
Just hope it helps to solve your issue.
Ian
Ian
hi Ian,
thanks! just have switched it as it should be and thought that the problem has been found and solved, but unfortunately same distortions still persist.
hi Ian,
Did you try the normal connection without the diode?
I suggest you asking for advise from Oliver to see what he get back to you.
I have his red PCB, but I still have no time to test it.
Ian
Clock & Signal Terminations
Hi Ian,
2 questions I hope you (or some other seasoned expert of the many on this forum) have time to answer...thanks!
Are there any specific termination / load requirements for the output signals (clock,data) of the I2S to PCM board, on the DAC PCB I am laying out? This would be in single or dual differential mono mode.
Also, I asked this in the GB forum, but for correctness, will as k it here:
Is there a significant difference (by you or reported) in actual (or perceived) sound in using the I2S to PCM PCB, over the original version FIFO and re-clock PCB? (as I have now)
This would be with respect to the TDA1541 running NOS.
Gary
Hi Ian,
Gary
Hi Ian,
Gary
Hi Gary,
1. You don't need any additional termination on all signals, because all signals were source terminated and matching 50 ohm impedance cable or trace
2. PCM borad was designed for many multi-bit DACs which do not accept I2S signals. PCM board does not have jitter elimination function as a FIFO does. So, if it works together with a FIFO and good clocks, the sound quality would be better .
TDA1541 can accept both I2S signal and PCM signal, however some diyAudio members and I confirmed that it sound better with driven by PCM signals .
Ian
Hi Gary,
Ian
Hi Ian,
Thanks! I absolutely meant when the PCM daughter board is connected with the FIFO, and not just by itself with an I2S source. I understand the functioning of each board, no issue there. The question was answered by the last line of your reply. On this build, going with the AD1865N-K. TDA1541 running fine.
Gary
Thank you, Ian!
Just wanted to say a quick thank you to Ian for the work that went into the I2StoPCM converter. I've been "playing" with a dual-differential AD1865 config using a raindrop-hui eBay board found in the "junk" drawer..... Thank you, Ian!
Ian
Cheers Ian,
removed the diodes, check all TDA's power supplies, made a mod to Oliver's dac (DEM oscillator), unfortunately the sound is still distorted.
Do you have any ideas what else could be checked?
Thank clivem for your great news. With the PCM board, it would be more flexibility to play with different multi-bit DAC configurations. Keep going with your good job and let me know for your progress. Enjoy your music .
Ian
Cheers Ian,
Hi deses,
Did Oliver get back to your with some advise? I didn't find problem from your pictures. Just hope I can see the waveform which could tell exactly what was wrong.
If it would be any help, I can sent a new PCM board to you to confirm they are good.
Is there any suggestion from anyone else?
Ian
Cheers Ian,
Just in case there is any help:
http://www.diyaudio.com/forums/digi...rsal-i2s-pcm-driver-board-53.html#post3621653
Ian
Hi deses,
Did Oliver get back to your with some advise? So no clues here. Anyway I didn't find problem from your pictures. Just hope I can see the waveform which could tell exactly what was wrong.
Ian
we just rechecked the connection with TPA transceiver board and it turned out to be correct. I decided to try another spdif board that should come soon.
Meanwhile I was trying to connect PCM board with Amanero and got the same results. I doubt there is something wrong with your board, but anyway thanks for your kind offer!
could you please elaborate a bit where to connect the scope?
- Digital Line Level
- Drive NOS AD1865/62,PCM1704/02/63,TDA1541 from FIFO: Universal I2S-PCM driver board
