Well here's my first proto build on the BK 12 speaker box. Its almost right? The top corner peices were not cut right and the bottom angle peice is cut a little short but, I wanted to see if I could build this box. It took me a little while but, I got it done. Thanks Scottmoose and Dave. I will be building a fresh pair of these in the next month. N.S.
P.s. I cut the wood using a circular saw and clamps to hold the wood in place. So again not to hard but, it took time 😉. Now if I had a table saw it would have been done asap 😀.
NS,
Why don't you just use the speaker box as built? It will work fine. From the sims I see that small differences in angles will not make a huge difference unless it is a throat dimension or channel spacing. It would be a shame to waste that build and all that wood. I think it looks pretty good.
NS,
Well you might be right. I think I will keep it and use it as a center channel speaker? I know it would be a shame to waste all that wood. My wife had said the same thing you did about wasting the wood. Also I use 3/4 of a inch not 5/8's of a inch as it has said in the plans. Well again thanks for the encourgement. N.S.
Here is a photo of my "experiment" in the rough mock up stage. I have a super tweeter in parallel w/ a 0.66 uf 250v cap to tone it down to my liking. This setup, along with the baffle, make for a nice listening experience.
Again...the Alpair 7 drivers are wonderful.
They're finally done.....🙂
...... and this 6197 SEP ( 2.8 watts ) amp will drive them 😀 .
Those risers are attractive. Just be aware you'll loose some floor-coupling. Tradeoff between that & getting the driver further on-axis with the ears for those with higher chairs. 😉
Thanks guys ! It took me more than I anticipated to build them since my cabinet making skills are pretty limited . I did not rush, took my time & followed step by step instructions .Very pleased the way they came out.🙂
These are 3" thick maple butcher blocks 10"w x 5"h.
First of all many thanks to you & everyone else who was involved designing these horns. I actually added 1" wooden isolation cone ( pics ) underneath the horns ( about 5dg tilt angle ).To support back of the speakers I used kitchen cabinets shelf brackets (pics ).
Great job! How big are those stands? I'm thinking I should make a pair myself.
Looks really nice - great wood working skills there. I never understood why speakers sometimes have sharp spikes on the feet that will concentrate all the weight to a singularity that will either cause damage to the floor or whatever they sit on...
Because some people have carpets, and spikes were originally intended to pierce these to improve stability (viz. to stop the speakers falling over whenever anybody walked past). The original purpose has become a trifle diluted over the years.
A modern interpretation of a classic. Another flat-pak to increase diyers choice.
My apologies for digging up an old thread. I'm looking for a HornResp model of this design. Is one available?
Not that i know of.The design was done with MJK (a step up from HornResp IMO) and a number of proprietory tools.
dave
dave
dave
I might put together a model this weekend if I have the time. It looks fairly straightforward - rear-loaded horn with a damped back chamber, horn in four segments... Are there any impedance measurements of a built horn available that I can use to compare against the HornResp model?
any problems using mdf for this build? I know mdf is considered less resonant than coated plywood but I have a bunch of 3/4 mdf and was considering using this for all of the build except the front baffle as shown in a previous post
thanks
thanks
Huh?
You can build out of MDF, but the enclosure will be more coloured than if you did them out of good ply. 18mm MDF is about the same stiffness as good 12mm ply, but has much higher energy storage,
dave
well maybe I used the wrong terminology , I meant a more "dead" ,less bright sounding cabinet ? hell, that's probably wrong also😕Huh?
dave
thanks for the help
This is one of those topics that can quickly devolve into religious / polemics territory - suffice to say that the physical characteristics of the two materials (MDF / high density plywood) are quite different, and those differences do affect the sonics.
Anecdotally, based on a few comparative builds from over 10yrs ago, I find the plywood enclosures to sound much "faster" and "musically consonant" - those are not scientific terms 😀
- Full Range
- Madisound BK12m
