DAC-END R (ES9018) full assembled board - version 2
List Update !
Hello everyone,
I have added my name on the list.
Still 9 to go to 20....
Vincent
1. adeveza: DAC module + amanero + output stage + transformer (Complete Set: Item 6)
2. papapew: DAC module + amanero + output stage + transformer
3. smokingdog: DAC module + output stage
4. gde3: DAC module + amanero
5. villanueva: DAC module + amanero + output stage + transformer (item6)
6. MattMax: output stage only
7. CAAD: output stage only
8. blackberry: output stage only
9. Mas Penk: DAC module + amanero + output stage + transformer (item 6)
10. rade95: output stage + chassis
11. vmoreau : DAC Module
12. edbk : Complete dac (item 6) (tested before shipping please 🙂 )
13. sandor: Complete DAC without output stage (option 6 without option 2)
Here's ES9018 DAC V2 structure. I invite you to watch!
Thank you
About the new shunt for V2. change for the opam shunt in V1
HAK shunt regulator
and shunt regulator is designed to supply dac.
Here, together with the help and assistance of members Keantoken-a good one simulation and electronic theory, I have perfected it and call it the HAK-shunt!
Optical loss is very grateful for his help!
Please see the simulation results for the measurements!
Thank you!
9. Mas Penk: DAC module + amanero + output stage + transformer + chassis
12. edbk : Complete dac (item 6) (tested before shipping please )
Please write your nick to the list DAC32 GR V2.
Thank you.
20 .
I will start producing the DAC-END R V 2, when we have a sufficient number of 20 participants registered members!
thanks again!
quanghao
Thank you.
14. Erlend Sæterdal: Output stage only.
20 .
thanks again!
quanghao
Numero 14 Number 14
