Mark Audio Alpair floorstander, pensil - horn or?
attachment.php
Well, made a quick comparison between the 10p and the 12p-pensils.
The 10p is prettier, but the 12p isn't really frighteningly big. I am used to OB atm.
I speak under correction, but to the best of my knowledge, like most small companies to date MA have employed their own test gear but used the anechoic chamber in the factory where they hired production space. As I understand it, they are currently moving to a dedicated facility where they will have their own chamber.
OK, I may be diving into a swamp here....
I am planning on building a pair of 10ps. The plans show Baltic birch. I was thinking about MDF (the good kind) and laminating with veneer.
I noted bad karma about MDF. Could someone enlighten me on the issues? The MDF that I would use is a very high quality type, and cuts like butter on my friends contractor table saw.
Thanks for any advice.
I would believe the accuracy of Mark's anecoic factory measures before anything done by us rookies in the field.
Unlike some manufactures he makes no concessions to "optimizing" the measures for marketing purposes.
dave
The measurements from another site were done by a semi-pro in a nearly anechoic facility. He's paid and he uses a very large shop are. It's the top 3 or 4 octaves that really don't require an anechoic chamber anyways. And that's where I see the most descrepency.
I'd rank other manufacturer's as more reliable. All in my opinion.
Hey Jeff. I seem to get caught up in these kind of tug-of-wars 😛 I just saw your comment and wondered if there was a 3rd party or something backing up Mark's literature. I was curious because I really like the sound of MA drivers, but have always had a hard time with his frequency response data. Hope I'm not a downer.
