As i said, N & P devices are not the same.Many thanks. This answers all my questions. Will get the original reg back in place and report. Difference between the two halves of the ALF is still disturbing...
In my models, 2SK1058 need 1.4V, while 2SJ162 need -0.92V. for the same 160mA.
Yes, the reg voltage is gate to gate (so, in my sim 2.32V.)
1.25V of TLVH431 is perfect: it was unbelievable L.C. made such an error to use a 2.5V Zener. Everything is perfectly clear, now.
Blew up a power device. Replaced it. Now, even at the lowest voltage of the bias spreader - 2.5v - there is too much current through the outputs - about 360mA. Scratching my head...
Hi
![wave :wave: :wave:](https://files.diyaudio.com/forums/images/smilies/wave.gif)
VSSA PCB from GB went into smoke? Very rare occasion hehe
![hot :hot: :hot:](https://files.diyaudio.com/forums/images/smilies/hot.gif)
Amp is so simple that the problem can be detected in 5 min and repaired in another 5 min if the board was not in flames.
![magnify :magnify: :magnify:](https://files.diyaudio.com/forums/images/smilies/magnify.gif)
And yes, bias regulator is TLVH431.
Regards L.C.
![cheers :cheers: :cheers:](https://files.diyaudio.com/forums/images/smilies/cheers.gif)
And yes, bias regulator is TLVH431.![]()
Agree. Overlooked the tlvh prefix completely and the 5 minutes stretched into... rather not say
But on the plus side got to take down the transfer curves of both complementary devices and found they are not alike at all. Even at very low currents.
Clearly shown in ALF's datasheet. Are there on the market any 100% complementary mosfets?
No matter what, nice to have reason and fix. Good listening weekend..........Oops. I may have replaced it with a plain vanilla 431.....
![c_flag :c_flag: :c_flag:](https://files.diyaudio.com/forums/images/smilies/c_flag.gif)
LC I see you used 3 different caps (for testing)
Panasonic FC
Muse KZ
Nichicon Gold
Can you give me a short notice on the end why you picked Nichicon Gold
How those caps influence the sound of the amplifier
Please let me know, of course from other GB member who tried different caps your opinions are welcome to!
Thank you very much
Greetings G
Panasonic FC
Muse KZ
Nichicon Gold
Thank you very much
Greetings G
Caps are not perfect. They have serial and inductive parasitic properties, not always linear, depending of the currents and frequencies. Depending on the way they are manufactured.How those caps influence the sound of the amplifier
Those parasitic properties influence the way they are able to stock and give back currents. And their impedances.
So they have an influence on phases at low and high frequencies, levels of AC signals depending of their frequencies, and the dynamic behavior.
Once you have designed an amplifier with theoretical values, and because the real behavior of a given electrolytic cap is difficult to sim, the best way is to do what L.C had done: Try and compare, both measuring and listening.
Hi
Re : VSSA and SMPS power supply .
I want to know whether the issues of the R19 and R20 has been taken care off in the second batch of the group buy pcb?
thanks
kp93300
The atatched BOM ---want to confirm that the BOM is for one channel only.
kp93300
R19, R20 are in recomendation to be replaced with pulsed current ones. But according to the last shootout test I would recommend to shorten serial diode D5, D6 and resistor R19, R20 with short wire. There is an improvement noticed in bass region if serial R-D is shortened.
The BOM is of course for one channel only.
Regards, L.C.
May-be replaced with little cap multipliers or little high voltage regulators ICs ? It is only 15mA.There is an improvement noticed in bass region if serial R-D is shortened.
Both can give better common mode riple rejection than any LTP and improve dynamic, on my experience. And, of course, differential PSRR as well.
Worth a try ?
Is there a schematic with component numbers?R19, R20 are in recomendation to be replaced with pulsed current ones. But according to the last shootout test I would recommend to shorten serial diode D5, D6 and resistor R19, R20 with short wire.
The one at #300 has no component numbers.
Hi LC
Thanks for the reply.
I quote
"R19, R20 are in recomendation to be replaced with pulsed current ones. But according to the last shootout test I would recommend to shorten serial diode D5, D6 and resistor R19, R20 with short wire. There is an improvement noticed in bass region if serial R-D is shortened."
Unquote
Do you mean to short these 4 points --- R19, R20, D5 and D6 with a short wire at each component if using smps power supply?
kp93300
I quote
Unquote
kp93300
Hi
Can someone confirm whether the panasonic FC caps fit the pcb in terms of spacing for the lead and the overall diameter of the caps
EEUFC1H102 - PANASONIC - CAPACITOR, 1000UF, 50V | element14 Malaysia
EEUFC0J222 - PANASONIC - CAPACITOR, RADIAL, 6.3V, 2200UF | element14 Malaysia
thanks
kp93300
thanks
kp93300
They look like a good fit to me.
The case diameter on the 2200uF/6.3V is 10 mm
which is even smaller than the recommended cap.
so even better fit.
The Lead Spacing and External Widths are the
important specs. All good.
Capacitor dimensions for VSSA PCB:
- 10 uF/63 V, MKT, Vishay-Roederstein, 2 pcs
Lead Spacing: 15 mm
External Depth: 8.5 mm
External Height: 17.5 mm
External Width: 18 mm
- 2200 uF/6,3 V, FG, Nichicon, 2 pcs
Mfr. #: UFG0J222MHM
Lead Spacing: 5 mm
External Diameter: 12,5 mm
External Height: 25 mm
- 1000 uF/50 V, FG, Nichicon, 4 pcs
Mfr. #: UFG1H102MHM
Lead Spacing: 7,5 mm
External Diameter: 16 mm
External Height: 31,5 mm
so even better fit.
Lead Spacing: 15 mm
Mfr. #: UFG0J222MHM
Lead Spacing: 5 mm
Mfr. #: UFG1H102MHM
Hi
thanks
kp93300
Each R+D assemblies, they are in serial, just shorted. Means the current sources and VAS directly connected to the main rails. Something you can compare, listening, in your real build.Do you mean to short these 4 points --- R19, R20, D5 and D6 with a short wire at each component if using smps power supply?
kp93300
Doing this will reduce PSRR of the amp, so, greatly depend of your used PSU.
- Vendor's Bazaar
- VSSA Lateral MosFet Amplifier
