Best solder and wire for Pass diy amplifiers ?
No matter what wire or solder you use, you won't get a good joint if your components have oxidation. I keep a small piece of fine steel wool on the bench and clean the leads of my components right before installing and soldering them. For large joints, I also put on a little liquid flux. Cleanliness is key to a good solder joint.
YES
Thanks, soundhappy. Brianco, thanks for pointing out that part of the JC blowtorch thread. Interesting discussion. I notice that at least one person thinks that steel wool has contaminants that could interfere with soldering. Based upon this, I am thinking about trying brass wool instead. Or Scotchbrite pads.
