CFA Topology Audio Amplifiers
Have done a 1kHz sim on my amp design at 100W/8R output and get 0.000011%. Is this suggesting that loop gain / feedback can be used to overcome this barrier at 20kHz and that the diamond input is not the limiting factor yet? It's more likely the output stage remains the bigger problem?
I don't know. That's why I'm asking the question.
For 1ppm 20kHz, you have to get everything good. When you've peeled away the OPS layers (I do this with 'pure Cherry' around OPS & VAS in #499), you have to look at the IPS.
It's complicated cos the Diamond IPS is very linear in itself. Depending on the exact topology, each side can be considered a Baxandall pair where considerable distortion cancelling occurs. Whether you can split this into an emitter follower (outside the FB loop) and a common emitter stage (inside) is part of the question.
I hope the deafening silence is evidence that Diamond fans are furiously preparing definitive answers to this. 🙂 Guru Wurcer?
But 'pure Cherry' & TMC are difficult with the 'symmetrical' topologies that CFAs seem to demand .. or rather my naive efforts don't show any improvement with these 'advanced' compensation methods.
This is essentially where I believe the work is to be done. Pure cherry if I understand it correctly is a capacitor between the amp output and VAS/TIS input. The diamond input is supposed to provide "current on demand". This may mess the cherry comp up as the diamond will fight it. I have done some quick sims on my amp and with a simple cherry cap (with no other comp methods) the ULGF was up at 68MHz. Totally unrealistic.
TMC with some tweaks does work well.
Remove the output LR R19/L1 network , replace it by a short circuit
and re do your sims.... 😉
I test on a resistive load connected BEFORE the inductor down to 1 ohm (1-2 V pk to pk) and there should be no overshoot or peaking - clean square wave.
But with capacitive loads, I only do this after the inductor.
I usually use between 0.6 and 1 uH and it's enough to handle really terrible cap loads.
That said, I like 60 deg at least PM and typically 10 dB of GM.
Bonsai - I have tried to compare input stages but inexperience and a general confusion is occurring. I think I need some help to establish an LTspice setup that would allow an apples vs apples comparison to be made. Just changing the feeds to the collectors disturbed the whole setup of the amp and did not allow a fair comparison.
I've also been thinking about this 1ppm proposed limit. Firstly, just to confirm 1ppm = 0.0001%. Have done a 1kHz sim on my amp design at 100W/8R output and get 0.000011%. Is this suggesting that loop gain / feedback can be used to overcome this barrier at 20kHz and that the diamond input is not the limiting factor yet? It's more likely the output stage remains the bigger problem?
Generally, in a well designed amp, the class AB OP distortion swamps everything else. Hence the earlier suggestion by Jan to look at the front end in isolation and then as a second step, attach a practical OPS and move forward from there.
I don't think I can measure 1ppm 20kHz this Millenium (though I might take Marshy up on his offer) For a commercial amp (or even a 1 off) I'm likely to abandon stuff that few, if any, people can see. Top of the list would be the input cascodes which finally pushed THD 20kHz below 1ppm and maybe even the VAS enhancer. 🙂
This is justified as even Guru Wurcer's SWOPA only shows some harmonics (not THD) at 1ppm level and then only for stuff like voltage followers.
___________________
mcd, I'm not proposing 1ppm as a limit or even a target. Just pointing out that I my eyes glaze over if stuff more complex than my #499 circuit dun achieve 1ppm 20kHz.
If your circuit does this with with an even simpler circuit and meets other important stuff like stability with wonky loads .. then I will grovel at your feet. 😱
To me, it looks like simple CFAs do better than simple VFAs. Can't see how to get better complex CFAs at the moment .. but that's what I'm hoping to get from this thread.
___________________
There are several myths about CFA vs VFA which should be addressed. One of them is that CFAs are noisier. This is only possibly true with evil Diamond IPS.
Simple CFA IPS like with VSSA and my #500 have less Ein cos at least 2 theoretical & 'real life' reasons.
Remove the output LR R19/L1 network , replace it by a short circuit and re do your sims.... 😉
Are you suggesting we design amps without an output inductor network?
I know of only 3 commercial amps that are unconditionally stable with load without this. None of them would be considered 'low distortion' today.
There are many Golden Pinnae amps without output inductors. You may like to try my capacitative load test (and more relevant, the big guitar speaker) including mild overload on these.
This was of great concern for me in my previous life as a speaker designer cos dem evil inductors made amps fussy about speakers impedance 😡
_______________
mcd, is this your http://www.diyaudio.com/forums/solid-state/236002-amp-design-attempt-number-2-simpler-24.html#post3608505?
My small brain has problems figuring out the compensation. The 82ps C5, 12, 17, 18 & R37, 43 look sorta TMC but from U22, 23 emitters instead of the output.
But C17, R37, C13, R36 look more like TPMIC.
Dunno what the 'FB' node is on the schematic 😕
Can you explain what is the intended scheme please.
What's needed in this thread is that someone explains how to calculate values of resistors for the given simple CFA template. Then explain/describe the open-loop action of the circuit and what result it causes when the loop is closed. That might help people understand the current-based push-pull action of the circuit.
So far a large part of this discussion thread tends to have a bit of an audiophylic appearance concerning CFA.
Excellent suggestion, MagicBox. I'll look forward to seeing that.
Bob
Christophe, Thanks for this is very careful and detailed comparison.
My only caveat is that without EKV models for the output MOSFETs, THD is suspect. Bob Cordell deals with this in his book. I hope he finds and publishes his EKV SPICE models so us unwashed masses can have a play too. 🙂
But I think there is no doubt now that simple CFAs like VSSA will equal & beat simple VFAs on purely technical grounds. I would very much like to complete the circle and conduct Double Blind Listening Tests on these but will probably be unable this Millenium 😡
The simple CFA is also simpler than the 'equivalent' VFA. I have a strong belief that 'simple' will sound better than complex for the same technical performance and have some listening test results that support this (alas all with VFA).
___________________
On a purely practical point ..
Do you know what JFETs LC uses for his IPS CCS? Very few JFETs suitable for this are 35V or more Vds. They don't have to be complementary which saves us visiting the Unobtainium FET Shoppe. 😀
___________________
Bonsai's qx_Amp_6
Here are some circuits to play with.
The qx does about 10ppm at 325W, while the kx is a whole lot worse until you change the AFEC resistor to 120 Ohms, and then you get quite good peformance.
Andrew, I give up. I started playing with qx_Amp_6 and stopped saying I'll find the SPICE models later.
MUCH LATER .. I still can't find them. Any hints & links?
