L'Amp: A simple SIT Amp
Here's mine :devilr:
A question here about the bias supply:
Would it be possible to use the bias supply schematic in http://www.audiohobby.com/pdf/lamp 193V.pdf but with an 18V trafo winding instead of the 15V in the schematic without modification or should some values be changed?
feel free to use 18Vac without any modification ; of course - voltage of first cap must be at least 35V
....... But I read somewhere it shouldnt be more then 6mm.
I hope you are not believing in everything written on the net
some ppl are way more dangerous than Tom Sawyer , when pursuing others to paint that fence :rofl:
same as with heatsink - heatspreader can't be too big ......
