L'Amp: A simple SIT Amp
Pass DIY Apprentice
Joined 2001
I just came upon this page: ƒjƒtƒeƒB�[”*Œ¾�W
As you can see the Tj is 120 C.
I assume but cant measure, only put my hand on the heatsink, that my SITs are running at 50-60 C whit 50W disipation at
ambient temperatures around 30 C...
I assume thats still in green zone.
Do you have a temperature probe?
I got the probe and measured the temperature of the transistor case (drain),
it is 60-61 C and the heatsink has around 53 C...
Need to make correction.
The Case temperature of the transistor after 2 hours of operation by
ambient temeprature 29 C is 75-80 C. The disipation is 52.7W.
I assume the Tj is even more!
I think I will have to lower the disipation to 40-45W.
52.7W? Which version did you build? What's your Vds/Id?
Also, using the thermal resistance from case to junction may result in a higher than expected estimate, so there's a little bit of room in there.
The Vds is 74V and the Id is 0.85A, the gate has -12V.
I build my own version whit parafeed topology and output transformer.
For insulation I use aluminum oxid, I bought here: Link
1 amp output transfo !!! schema pleaaaase:cheers:
I am still working on the circuit, its an hybrid...Will post the schema
as I am finished.
This is a parafeed, so there is no current i primary.
I read something about an SIT SET in Linear Audio vol.4,
they used PASS SIT-1 and had an special made output transformer that
could take the current but didnt have enough inductance for low end.
The one and only
Joined 2001
This just in: I'm informed the 2SK60 is 1.5 Max. Is it fair to assume the 2SK82 is a little bigger?
I don't assume that. I have seen a 4mm spec on the chip, and all the mfr
numbers point toward 2.5 deg/w - 150 deg C junction max, and a 63 watt
rating at 25 deg case temp.
I have seen photos of dual chips in a TO-3 case, but from the curves I get I
don't think that's what Acronman is selling. I guess I'll cut one open if I get
bored.
:cool:
