100W Ultimate Fidelity Amplifier
Haha!
I just put 100k multi turn pot in parallel with 3k3 bias resistor so now I have excellent range of adjustment for bias....
Currently have it cranked up to 80mV across the 0.22 emitter resistors for around 360mA per device....sinks are cool and sound is awesome.
getting ready for my ax11
The mje340/350 is a very different pair of transistors from the bd139/140.
They are not a direct swap !!!!!
There are two types od mje340/350 (pinouts), I have on-semi ones and they are direct swap transistors to bd139/140, I have used them in FET-hex amplifier.
Very important is to check on which side the base is located, often in datasheet pinout is different to the phisical pinout!!
That tells me you have bought fakes.
It should tell you the same message !
Yes I know thet there are fakes on the market but I have bought them from very very good source and they perform very well (so far). In the datasheet (style1) please take a look at the pinout for onsemi mje340/350 is the same as pinout for bd139/140.
regards
How about these tandems for AX-11...
Output Trans: 2SC5200/2SA1943 (230V, 15A)
Drivers: MJE15032/MJE15033 (250V, 8A)
Pre-drivers: 2SC4793/2SA1837 (230V, 1A)
What is the max rail voltage it can handle safely?
I have these transistors at hand and planning to use it.
