Parasound 2125 2 channel power amp problem
Seems I was wrong, I do have normal sound out of both A & B speaker outputs after replacing the two op amps on the input board. The only way I can turn the amp off though, is to turn the volume down on the preamp and unplug the power amp. Could it be all I need to do is replace the relay because it's probably stuck in the on position? The OP Amps I replaced were LF353P what I found on hand, was some OPA2134pa amps so I used them as I have installed sockets once before, all I had to do was just plug them in. Should these be alright for replacements? if not I think I have some more LF353P amps somewhere. I also, installed extra decoupling caps along with bypass caps when I installed the DIP sockets. Since the power switch is a momentary push button type, could the IC chip that's also close to the relay be bad or, the electronic on/off switch cause this amp to come on by it's self just by plugging in the ac power cord? Even with the a and b speaker push buttons turned off, when I plug the ac power cord in, the small green L & R channel indicator lights up as if I had pushed the on off power button. The amp actually sounds better now with the OPA2134PA op amps in it. Thanks for all opinions/suggestions and possible places to get a service manual would be very appreciated. 🙂
I suppose you have checked that standy-by momentry switch S204 (loc A-5) is not stuck closed? And then there's the relay K501 to check. Sorry that's not much help, just repeating what you said already....
I noticed with the amp on no input/sound, that if I push the button like trying to turn on or off the amp I hear a light thump each time I push the switch. Should I assume, that the momentary on/off switch is not stuck closed? Could CD40135 at U1 also, be suspect as well as the relay at K501? Thank You! 🙂
Seems a reasonable assumption (that the switch is not stuck closed). A light thump, like a relay coil energizing? Give the relay a tap and maybe it will let go if that's actually the problem.
Of course U1 could be suspect, but check the simple mechanical stuff first.
I've tried tapping the relay but no luck. I have been searching the net for a replacement relay just in case it turns out to be stuck closed but, can't seem to find one anywhere any ideas? I'm going to take my ohm meter and check the relay and momentary switch soon for closed contacts. I hope it's not the IC chip I hate having to solder those things in especially, the tiny surface mount chips my eyes are not that good any more. 😀 Thanks Again! 🙂
Does the standby it is ON or OFF? Does the LED light changes when the standby switch it is press?
The way it is right now, I have no standby led lit up because as soon as I plug the ac power cord in the amp comes on without, pushing the on/off switch. When it was working right I turned the amp off with the switch then, the led standby light would light up. Unless the room is dark, you can't see the standby light. When the amp is on now, the standby led is not lit up. I hope I understood your question correctly. Thanks again! 🙂 pushing the on/off switch when the amp is on will not turn it off but just makes a light deep thumping sound through the speakers I have to unplug the power cord from the amp to turn it off now.
The standby switch what it is does it toggle the flip/flop On/Off and the light should come ON. If you check the schematic the switch goes to pin 3 and it is the clock. Every time you turn On/Off the switch the flip/flop toggle. Now the led light voltage it is coming from the + 15 volts. Check pin 14 of the CD4013B
for +15 volts. You should have +15 volts.
I plan to unhook my amp today and plug it in to another power cord for voltage testing. One symbol I don't understand on the schematic, is the red arrows with the tiny red F next to them what do those stand for? Thanks! 🙂
Good question, as it's not chassis ground or 'proper' signal ground, but some other kind of ground, "GND2"...
Is the schematic from Parasound (as there's a fair bit of Chinese on there)?
Yes it's from Parasound I emailed them about a service manual and they sent me three schematics. I'm beginning to think the K501 relay and on/off momentary switch are both fine. When I plug the power cord into the back of the amp, I can first hear K501 click then the output channel relays click next and I can also, hear K501 release when I unplug the AC power cord. I didn't get around to unhooking the amp again yet like I'd planned but, I'm starting to think it may be U1/ CD4013B or maybe, one of the transistors. The bad thing is if it's the IC chip, I don't know if I will be able to locate one I can order. Thanks! 🙂
