GD-Audio opamps
This is the circuit diagram of GD-Audio's Discrete Opamps OPA-Earth. This is the basic Opamp from GD-Audio and I am using the better design OPA-SUN. Someone said Burson's Opamp has very similar design as OPA-Earth.
see this link for details:
ºÍ§Óµ响
ºÍ§Óµ响
Hi guys, newbie modder again.
Quick question, which way should the disc spin on a CD67?
All discs rotate clockwise looking from top
If you have not done anything to the wiring connections the drive should not spin anti-clockwise. If that is the case it means there is something wrong with the servo circuit.Thanks
So if it's going counterclockwise?
Can you just swap the drive motor connections around?
Thanks Ben.
I have a couple of things to investigate as well as this all started when I changed the laser mechanism. So I'm going to backtrack and check everything was replaced properly. it's a while since I did it though. The mechanism has 4 pins that slide into runners on the transport. Am I dreaming or did they have rubber/plastic sleeves on them, or do they go in as they are?
transport
The runners have no sleeves they run direct plastic to plastic only grease to make it run smooth .The laser is mounted on shock absorbing rubbers tho x4.
hope that helps alan
Thanks Ben.
I have two players both with servo issues at the moment,While trying to test voltage from a good player i slipped and shorted a servo ic tca0370dp2 now my deck spins backwards flat out.
cheers guys alan
ps anyone know of a supplier for the ics
I also blew one of the same ICs in the past and got a replacement from eBay:
TCA0372DP2 Integrated Circuit x 1 pieces | eBay
servo
i may replace all 3 voltages are all over the place @ the moment. £5 each or there about.
thanks highlander alan
Check if the +/- of Caps C813 and 814 are correctly fitted. It seems you have lost the 5V supply to the circuits.
Checked the 5v supply. The 7805 seems okay. The display does light up btw, maybe didnt see it properly before. The other regs I installed near the driver ics' all measure around 8v. Any suggestions to have a look? Never had this fast spinning before.
re drivers
You should have more than 8v more like 10 to 11v plus and minus check voltage @ u148/150 should be +-10 to 11v pins 9 to 16 on tca 0372dp2 should be to 0v
suspect duff ic
regards alan
So you installed some extra 7808 and 7908 for the servo driver IC's?The other regs I installed near the driver ics' all measure around 8v. Any suggestions to have a look? Never had this fast spinning before.
Can you show or explain how and where you've added these in? Is there a chance you have a positive and negative regulator mixed up anywhere?
Don't forget to check for lifted pads. Seriously, I've had this exact problem lots of times.
I'd check around servo control and decoder, c505, etc
Another thing you can do is very gently touch the tops of some components while the disc is spinning and see if it affects it (being mindful of mains voltage, obviously).
Re: Regs, that's true... Hopefully you mean around 8v +/-!
Easy to check. Just refer to the driver reg pin-outs in the service manual and check the voltages are correct on each pin.
Apologies if I'm teaching my grandmother to suck eggs here - it's a fine line to walk.
Good luck!
Good luck!
Totally agreed with you Ben. I have encountered similar problem with copper strips of the PCB. As the PCB is more than 10 years old the strips can be damaged and peeled off easily in particular when too much heat is applied. I need to use jumper wires to bypass the damaged strips.
- Digital Source
- Marantz CD63 & CD67 mods list
