My_Ref Fremen Edition - Build thread and tutorial
On June 7th I brought home the package with boards and parts from the post. Everything came in great order! Don't have enough words to thank Dario properly! Great work! So, as per 'tutorial', first came the SMD components. Flux used was Russian brand. Somewhat fluid 42% neutral rosin gel. For solder there was a choice between Asahi Sn60 Pb40 and Chemet Sn63 Pb37. It was my first adventure with SMD parts and with many issues too. I was cautious not to overheat the parts. The proper method from tutorial failed to work for me. The solder string just refused to melt. Even when temperature was raised to 300 C. This method certainly needs getting used to! I ended picking tiny balls of solder with iron tip and applying them to the parts. If the ball was too large, it was rejected by whiping the tip. Something like one of three attempts to pick the right ammount of solder turned out successful. Strangely enough the Asahi 60/40 solder proved easier to work with. The result is far from perfect, of course, but possibly acceptable. Hope to try out the boards in a week or so.
You're welcome 🙂
What counts is result, any method is good until it works 😉
Seems pretty good from pic. 🙂
The MyRef puts out a maximum of ~50W into 8r0.
Two channels will total 100W.
Use a transformer from 100VA to 200VA for satisfactory operation.
For good performance I would go towards the upper end (160VA or 225VA).
Using a higher VA transformer does no harm.
can I use 1 toroid for 2 board?
It's possible and has been done but the original designer (Penasa) warned againt possible hum/ground problems.
You can start with one transformer and in case of problems you can buy a second one (identical).
what is the minimum value for the toroid?
Andrew already answered.
BTW I would add that R-Core 120VA (like Selectronic ones) seem to perform better than 225VA toroids (at least for the Toroid brand).
is 300VA 2x25 like this is enough? or maybe 225 is quite enough for My Ref FE ?
In case of toroids, higher VA means more subjective 'body' to the sound.
Also the answer vary according transformer number... 1 or 2?
For a pair od boards I would not go lower than 300VA, for dual mono (so TWO trasnformer) I would not go lower than 160VA.
If you choose to use toroids the orvekill config is two 300VA
Looks to me like you are shy of solder on almost all of the through hole spots. Know you don't want to burn anything, but I see a great need to reheat them and add some solder. The photo shows how easily one can miss a bad joint.
