Always the right picture!!!😉
PS: it will be nicer if you can find a BIGGER knob for the volume control and leave the other same size.
Many thanks for the nice comments...
I still have a (design-) problem... i got new solid chassis feets and volume knobs.
Which one of the volume knobs would you prefer?
I'm really undecided...😕
The bigger ones, great work.
Ok ok... i'll take the bigger ones on the right picture.
The vote was clearly! 🙄
Thank you so much...
And thicker means easier to trim to the desired value, the bigger, the more precision you get.Thick is nicer than thin, in this case.
Hello valvesound,
here are some inner details of the aleph (of cause it's very tight...)
I build it as a double mono construction with two transformers and two power boards.
I also integrated two separate soft start with separate speaker protection.
you see, every space in the amplifier is well filled... 😀
Gosh where in the world did you get those heatsinks 😉
I'd be real proud if my missus carried round a pair of those ();
My first effort into SS amplification
Here a few pics of my first effort into building a SS amp.
The amp is based on Rod Elliots P3A 100W power amp and the P88 pre amp. I added a speaker protection kit from Altronic.
The power supply is point to point wired, 42+/-DC unregulated for the power amp and 15+/- DC regulated for the pre amp. All run of the mill parts were used except for the Alps volume pot.
Looks very cool, especially next to the tube(?) amp. Can I ask how big it is in that case? (I mean outside dimensions)Here a few pics of my first effort into building a SS amp...
Well done looks great.
The outside dimensions are:
W:260mm D:200mm H:90mm (no feet)
Very nice, please consider drilling some holes for ventilation, maybe more heat sinking (depends on whether you hold house parties😀)
kind regards,
Harrison.
42 volt rails ..... minimal to non existing heatsink ....no ventilation you are on the very risky side my friend
I hear you, and Harrison. 🙁
The heat sink is on the small site. It has been playing on my mind as well.
Bear in mind that the bottom cover is cut out around the heat sink and that there is a corresponding air vent on top of the amp. So air can circulate.
But yes, when I made the enclosure I did not think ahead far enough. I did run the amp for a few hours keeping an eye on the temperature and at the listening levels I run it, there has been no issue.
I certainly take some learning from this amp build and I look forward to the next project when inspiration hits me.
Stephan
- Post your Solid State pics here
