out board power supply connection
Just read Tinitus,s thread
exactly as was suggested there
..... and the speakon connectors for power out to the amp case
I don't think Speakon was suggested
and the Powercon are for mains voltage
but you might be able to use Powercon safely, by 'reversing plugs'
meaning, a powercon cable would have normal mains plug in one end, and a Powercon female at the other end
and the box will have a male chassis plug mounted
thats the mains cable
so if you amp box have a fixed output cable with a male connector
and your power supply output have female chassis plug
this way you cannot connect any other way than the intended
hope I got that right 😛
with one hatch :clown:
a Powercon female chassis plug is actually intended to be used for mains out from a box :t_ache:
guess what's this ......
