and to discuss.....
even when I would take two monoblocks with the mono PSU, they are of course completely separated.... but
the canceling of higher order hum components would not happen, would it?
I see no reason to have canceling between two channels
in every case - dual mono ( be it common case or two separate ones) is superior , strictly speaking from energy level point
I look forward to Zen Mod's [and other's] Grand Sell-off of Monoblocks or stereo diyamps. Count me in. Really, what do you do with 10 of them [for example] sitting on the shelf and used every blue moon?; noting that you'll add another 5 or more to this resting collection in the future?que ?
house full with small monoblocks![]()
Best regards
Are dual transformers necessary or can you get away with single with 4 windings? ASSuming sufficient transformer.
I have one 800VA in Papa's Koan , with 4x18Vac secs
but , I put it there only because I already had it , not because I like it more than , say , two 300VA in same place
pretty much just measure of chosen insanity ; going dual mono is just part of broader kwayziness
Consider low frequency PSU crosstalk cancellation by running the two channels in opposite phase. 🙂
I thought.... firstfault....Nelson meant....second fault.... The resistors splitting will reduce the 100Hz, 200Hz harmonics, coming from the 50Hz (or60Hz ) current!
I will measure with my distotion program one channel splitted and normal and show you the results!
= common sense🙂pretty much just measure of chosen insanity ; going dual mono is just part of broader kwayziness:
By the way...
Why gets Nelson's resistor splitting idea so many negative comments....😕
Did it someone before and got worse results? 😱
Not negative from me. I have dual mono. May be a great thing. Ignorance is my current status.
I didn't said that his idea is bad - it is good , when having common PSU , in CRC fashion - to arrange it in that way ;
my comment was strictly speaking of - when you're going to make it for you , make it full blast
ya see what Pa made , when going Demonstration of Force route - 4 cases for stereo ......
ya see what Pa made , when going Demonstration of Force route - 4 cases for stereo ......![]()
Right ZM....we are not restricted by Commercial Cost Control issues.
Objective for us is ...how great we can get music to be.😀
if they all are not framed in generic-common FW case , we couldn't have so many of them ;
observe word "we" - even it's existence in context , along with spoken number of projects in subject is ........ outrageous
Funny Pa
Funny Pa
Funny Pa
..True 🙂 I'm working on very different one with unique case ....and it's taking me forever to complete.
If i didn't have gorgeous ZM inspired drek to play my music while i work on it ....😉😎
- F6 Amplifier
