My TO3 version of AX11 for more power.
Used BD679A instead of MPSA13
MJE15030/15031 instead of BD139/140
MJE340/350 instead of BC639/640
MJ15003/15004 instead of BD249/250
Also you need 2N5551 or 2sc2240 instead of BC546, if you use higher voltage.
please read:
http://forum.diyaudioproject.eu/index.php?/topic/118-simple-100w4r-amp-apex-ax11/page-9#entry3215
Check this and let me know if you found mistake.
It's late now in my place....
Beautiful as always. Thank you WILLY.
Just one small line forgotten . 100nf/100V needs to be connected to output.
Done. File sent....
Please check your mail, Enjoy...
Just another version...
with common heatsink for the driver (not tested).
regards Olaf
Nice work,
Cant wait for it to be released,i will build this as soo ans the common heatsink one gets released
Hi, the module is tested and works well. The sound is warm and clear and crisp and powerfull in the bass. I like it.
Heatsink comes from a old PC-grafics-card. All transistors stay cool.
regards Olaf
regards Olaf
coper side is for toner transfer,thanks for warning willy!
Thank you!!!
regards Olaf
Nice work, is there any noise on amp out?
olafk can send common heatsink for the driver pcb layout to shravanth.reddy@yahoo.com
thanks,
shravanth
thanks,
shravanth
No, there is only a far, distant noise on open input, should be normal because the circuit was completely open and not shielded.
regards Olaf
Hi Shravant,
See attached maybe this a bit better than the previous file.
how to us heat sink for BD139 and BD140
Fail both files are bottom layout
I openend both Files and they are correct. Look at the Apex-Logo.
Oh sorry i thought by component you meant the one in the picture,for etching i hould use bottom pdf.You should also add a black and white top component layout!,im etching this as soon as possible if i still have some clad
regards Olaf
Thanks for reply, enjoy in sound.
hai olafk I have just brought all components , tommarow I am going to make pcb
Hi Shravanth sir, I am new here from vizag. Can u tell me where can I get copper pcb clads or pcb manufacturer. Can u help me in this, I am too interested in doing this project. Or u can sell me one pcb. Thankyou.
- 100W Ultimate Fidelity Amplifier
