Yes,but im building the standard version so i dont go broke 😀
an mje15003 is 10 and an 2sc5200 is 4 money,but i will try to find something even cheaper like 1-2 money
4 romanian money units=1 euro,plus the fact that in shops they are more expensive and i want to build a 4-5 channel amp
Have you built a mains bulb tester? Sometimes referred to as "dim bulb tester".
Have you read up on the tester and why it helps stop you blowing equipment up?
yes i always use it,but the problem is i dont know hou to make a propre star ground,thats why my projects have been unsucessfull
A bulb tester and a faulty ground will NOT blow up your project.
It is faulty application of mains power by incompetent builders that blows up projects.
Only once a project blew up,the other times i just threw the chips out thinking they were faulty but it was the ground,but will a 25w bulb protect agains a reverse polarity on amp
AX11 with TO3 outputs
Wow can you post the etch file for this one please?
it was done by a friend of my,"Dude" from another forum.
here you go:
Looking on top view, B of MJ15004 was connected to .22R/5W on the output??? Or maybe one of them mounted under PCB?? Just confused maybe i'm wrong....
Yes, there is mistake, MJ15004 must be rotate 180deg.
Hello willy can you mail me PCB layout (silk screen,artwork,green masking layouts) for AX-11 to Shravanth.reddy@yahoo.com
coper side is for toner transfer,thanks for warning willy!
Thanks for correct pcb files.
Hi Shravant,
See attached maybe this a bit better than the previous file.
it´s ok - thanks Willy for warning about mistake 🙂
Cheers buddy....😉
- 100W Ultimate Fidelity Amplifier
