COOOLL!For freinds may interested of SANKEN version.
Thank's! 😉
wiljj can u share green masking layout also so I can make good looking pcb
Hello Shravanth,
Can you check post # 2079??
yup.. wiljj I saw post #2079 there is art work and silk screen but there is no green making layout
trying make pcb like this- http://www.google.co.in/imgres?q=pc...bnw=335&start=20&ndsp=12&tx=155.375&ty=60.875
trying make pcb like this- Google Image Result for http://www.dragonflyalley.com/images/YUanimator/YUSA-11-pcbBackB.jpg
You mean this one??
hai olafk I have just brought all components , tommarow I am going to make pcb
ok, I'm really curious.
ya. . . . but only yellow pads should be there
Maybe this can help.
thanks wiljj . . . thnk u very much that's what I need in two days I will upload my pcbs
can someone give me the pdf file for the ax11 with bd140 and bd139 and mpsa92 on same heatsink,it seems better
AX11 look very nice with SANKEN, thanks.
My TO3 version of AX11 for more power.
Used BD679A instead of MPSA13
MJE15030/15031 instead of BD139/140
MJE340/350 instead of BC639/640
MJ15003/15004 instead of BD249/250
Also you need 2N5551 or 2sc2240 instead of BC546, if you use higher voltage.
Part list:
1. MJ15003 – 1 pc.
2. MJ15004 – 1 pc.
3. MJE15030 – 1 pc.
4. MJE15031 – 1 pc.
5. MJE340– 1 pc.
6. MJE350 – 1 pc.
7. BD679A – 1 pc.
8. MPSA92 ( replacements 2N5401,BF421,2N5416) – 1 pc.
9. BC546 ( replacements 2N5551) – 3 pcs.
1. R22/5W – 2 pcs.
2. 220R – 2 pc.
3. 10R – 2 pcs.
4. 100R – 2 pcs.
5. 4K7 – 1 pc.
6. 3K3 – 1 pc.
7. 680R – 4 pcs.
8. 22K – 3 pcs.
9. 2K2 – 2 pcs.
10. 4R7/1W – 1 pc.
1. 47uf/63V – 2 pcs.
2. 100uf/50V – 1 pc.
3. 10uf/25V – 1 pc.
4. 330pf/63V – 3 pcs.
5. 100nf/63V – 3 pcs.
1. 1N4148 – 3 pcs.
PCB dimensions 94x90mm
1. MJ15003 – 1 pc.
2. MJ15004 – 1 pc.
3. MJE15030 – 1 pc.
4. MJE15031 – 1 pc.
5. MJE340– 1 pc.
6. MJE350 – 1 pc.
7. BD679A – 1 pc.
1. R22/5W – 2 pcs.
2. 220R – 2 pc.
3. 10R – 2 pcs.
4. 100R – 2 pcs.
5. 4K7 – 1 pc.
6. 3K3 – 1 pc.
7. 680R – 4 pcs.
8. 22K – 3 pcs.
9. 2K2 – 2 pcs.
10. 4R7/1W – 1 pc.
3. 10uf/25V – 1 pc.
1. 1N4148 – 3 pcs.
You're most welcome Mr. Mile...😉
post2097.
The pads around some holes look very small.
Is this a pic scaling problem, or is it a true reflection of the copper area available for soldering.
In my view these very small pads are far too small.
- 100W Ultimate Fidelity Amplifier
