Ladies and Gentlemen
Let me put all the informations in one and a right place (group buys).
Basing on alexw88's (shine7.com) experience, I've created my own project of PA150 (3xLM3886). It has been modified a bit, the size has been reduced, and some other tweaks have been made. I'd like to share the project with you (below). PDF file with switchable layers, try it! I'm gonna order the PCB soon, if anyone wants to grab a couple of PA150 PCB, let me know. Of course, tweaks still can be done before the order.
PCB layout:
http://airproject.drl.pl/PA150v18.pdf
Power supply up to +35/-35 VDC. LM3886 datasheet.
Details: PA150 - 3x LM3886 PCB assembly guide
I has been well tested by alex88. Testing and measurement:
DIY BPA300 6x LM3886 300W audio Amplifier
It is still the same project, except the capacitors which were moved from the bottom to the top, C10 (10u) replaced with wima (better solution), and some downsizing.
Anyone who is interested, just give me your e-mail address and I will send you some details.
Of course don't hesitate to ask questions
Hi, Marlowson
I am interested in the possible PCB deals on the BPA150 (originally by alex88). Does this board use smd or thru hole components? Also, what would be the estimated price per PCB? I am thinking of using a transformer to separate the + and - signals instead of the DR134 (I think) in order to bridge the two boards. Thanks!
Lo_tse
In the field of components - no changes. Both smd and thru hole as in former alex88's project.
Price 8 euro apiece if you're buying 4 pieces.
9 euro if buying 2 pieces.
+ delivery man
Marlowson,
Thanks for the info! Hmm, I recall that there were quite a few smd components on the board. I am not that proficient with soldering smd - my right eye sight is not great. Anyway, a little off-topic, is there a BOM for the BPA150 archived somewhere. I would like to check to see how many smd's that I have to tackle with.
Thanks!
Reagards,
Go to the shine7.com website where alexw88 has almost all of the original information available for the bpa300 build. He originally set out to clone the Jeff Rowland amp and did a fabulous job.
Tad
Thanks!
I finish mine a few months ago, i disarmed it to work in the case and when i put back today i had a short circuit on the psu. the LED light start smocking and then blew up as i was shooting it down.
psu,
I replaced the capacitors from 4x10000uF to 4x22000 last week and i retoched some joints in the area, i may have mess up, i hope the flash did notruin one of the capacitors.
New PSU in. Soft start added and not smoke so far. will test sound with new caps tomorrow.
Great recovery yakusa !
Looking forward to your impressions after a little burn-in. Your success prompts me to get my set back together soon. I stole the power supplies for another project but they can come back now. I'm using a Jantzen CrossCap now but want to see what the new Audyn Plus series will do.
I'll post and we can compare notes.
I'm using the Clarity Cap SA series. They sound good and are not that expensive.
Alex
I'd rather use the boards from a forum seller, they looked of better quality. But you can always resort to ebay as a las option, just a tip.Can anyone spare 4 of these boards for sale?
1pc LM3886 x3 150W Parallel Mono Amplifier PCB | eBay
- Group Buys
- BPA300 Round 2
